hp in jdm h22a motor?
Old Apr 3, 2012 | 09:00 AM
98cfprelude's Avatar
Default hp in jdm h22a motor?
i have a 98 prelude and would like to eventually swap my current h22a to a jdm h22a....how much hp would do these motors have...I am seeing different results from different web sites and i would like a legit ansewer before i make any decisions
Old Apr 3, 2012 | 10:16 AM
wh1teredneck's Avatar
Default Re: hp in jdm h22a motor?
I believe the h22a JDM version comes with 220 HP and 163 TQ Stock
Old Apr 3, 2012 | 10:52 AM
carnot's Avatar
I thought the type-S made ~220, jdm h22 made ~200, and usdm h22 ~190...
Old Apr 3, 2012 | 10:58 AM
Basik_One's Avatar
I believe thats correct, but of course thats at the crank. Anyways op why is it that you want to swap your engine for a jdm h22?
Old Apr 4, 2012 | 07:23 PM
i wanted to have a jdm type r (i know its called a type s but I think type r sounds better) prelude....plus the current motor i have as of now has some serious wear and tear and i want to make it a jdm prelude, but the reason why i wanted jdm in the first place was for a slight power increase and i heard that the jdm motor can handle more, incase at some point i may feel like slapping a turbo on it..........all in the near future of course
Old Apr 4, 2012 | 07:24 PM
im having trouble decifering which engines are which on ebay though i would like to go for the type s because of the slight power increase
Old Apr 4, 2012 | 07:26 PM
nm i retract my previous post
Old Apr 4, 2012 | 07:41 PM
horsepowerless's Avatar
thats the type s.. those are rare
to answer your question the h22a has the exact same output as the 5th gen h22a4. which is your motor. if i were you rather than doing an engine swap i would just rebuild your current engine with beefier internals to give it the same or more horsepower than the type s
Old Apr 8, 2012 | 07:59 AM
LatnKng's Avatar
Icon3 Re: hp in jdm h22a motor?
+2!! DeF!!
Old Apr 8, 2012 | 10:42 AM
minilogoguy18's Avatar
If you REALLY want to spend the money on a red top H22 then get the full swap from the Accord Euro R, best of the 3. You can't even use a Type S unless you are in a SH since it has ATTS and there is nothing special about the SiR S-Spec, Euro R gearbox is way better.
Old Apr 8, 2012 | 11:45 AM
daveypower's Avatar
i think type S is 217 and the SIR version is 220hp, best idea would be an accord type R (UK) or euro R (JDM) engine, the gearboxs have same ratios in both i belive but they could still do with a final drive gear replace. the 4th gen preludes had a 200hp jdm engine.
Old Apr 8, 2012 | 02:06 PM
SpoonMotorSport's Avatar
jdm h22a blacktop manual=200hp
jdm h22a blacktop auto=190hp
jdm h22a REDTOP s-spec/type-s/euro-r=220hp s-spec and euro-r come with lsd 5speed where as type-s comes with ATTS
hope that helps!
Old Apr 9, 2012 | 01:12 AM
OmerJaved36's Avatar
+3........well explained............
chikin pickle
Apr 6, 2015 10:05 PM
Jdmh22allmotor
Jan 9, 2012 08:10 PM
umair
Feb 25, 2009 12:11 PM
brandon_wright92
Feb 21, 2009 02:12 PM
jdm4dr
Sep 26, 2002 03:56 PM
