89 Civic Delete help!
top connector is a purge valve you can just unplug it thows no codes the plug below it is a map sensor you need it but you can relocate it ....the bracket can be removed and you can remove your charcoal canister too
Luckily i have no smog or emissions here so im good.
I have a dpfi manifold.
Blue - Is that the line where the fumes come out and do just leave it hanging down?
yellow- do i just take out that line and cover it where it leads to the manifold??
Black-How do i go about delete that whole part? As far as the lines coming out. Do i do cover them up on the manifold?
88 rex
Aug 4, 2005 04:58 PM
VTECAcuraGSR
25
Mar 30, 2005 02:28 PM
Westrock2000
May 19, 2003 06:02 AM
