poor mans type r sounds like rocks in head
Old Apr 2, 2012 | 07:20 PM
TehTaylor's Avatar
Default poor mans type r sounds like rocks in head
I have a jdm b18c bottom end with pr3 pistons and a pr3 head with a oem 3 layer head gasket. when i assembled the motor and put it in the car and started it you could tell the valves needed to be adjusted bad, so i did a valve adjustment for a b16 .006 on intake and .007 on exhaust. after i did the adjustment i started it up and it sounded nice and quiet but the next day it started sounding like there was something bouncing around in the head. i took the valve cover off and took the cams out and ran a magnet through it to make sure nothing was in it and couldnt find anything. now im guess the valves hit the pistons and are now bent. i would just like to get some other opinions on what it could be. any suggestions would be helpful, thanks
Old Apr 2, 2012 | 08:07 PM
danielcamargo's Avatar
Default Re: poor mans type r sounds like rocks in head
What type of gas are you using? what kind of ecu are you running? Ive heard an engine Ping before and it sounded like pebbles coming from the head.
Old Apr 2, 2012 | 08:42 PM
afrikainside's Avatar
Are you running adjustable cam gears did you check the belt tension ?
Old Apr 2, 2012 | 09:33 PM
anothersickhatch's Avatar
Most likely, the valves didn't hit the pistons. There should be plenty of clearance with those parts. Is the motor tuned? Did you make sure to tighten all of the valve nuts? Are any of them missing? B-series engines are going to make that sound, especially if you have upgraded the cams and valve train.
Old Apr 2, 2012 | 09:46 PM
Dc4LsTeG's Avatar
EK9
X2 on checking the valve adjustment nuts. Maybe also take a look at your lmas
Old Apr 3, 2012 | 06:22 AM
TehTaylor's Avatar
The nuts are all tight because the next morning i went back and checked everything to make sure it was still in spec. i have been putting mid grade gas in it. i am useing stock b16 cams with stock cam gears as well. im running a chipped p28 with a b18c5 basemap and its not tuned. i did run the car pretty hard a few times the day before i adjusted the valves, could that of done it?
Old Apr 3, 2012 | 06:23 AM
TehTaylor's Avatar
The sound is like something is hitting the underside of the valve cover, its hard to explain
Old Apr 3, 2012 | 06:30 AM
speedooo's Avatar
Could be lma's at idle. How old is the head?
Old Apr 3, 2012 | 07:28 AM
Dc4LsTeG's Avatar
EK9
That's why I said take a look at your lmas
Old Apr 4, 2012 | 10:29 PM
A couple days ago, I was going crazy thinking i bent a valve or something. I have a CTR piston setup with some pro2s and bending a valve is a huge possibility for me. Either way, I tried a valve adjustment checking the cams, looked all over the motor. Then i moved the valve cover a little bit to the right so that the cam gears didnt hit the valve cover and back to normal.. It was a wreck but thats what it was For me.
Old Apr 6, 2012 | 06:21 AM
1997boostedeg's Avatar
My advice take the head off and take it to your local machine shop and have them look at it and pressure check it and that will tell you really fast if your valves are bent cause they wont seat and that will affect alot of things did you check your valve lash?
Old Apr 6, 2012 | 06:45 AM
Silvertune's Avatar
Chances are you didn't adjust the lash correctly that there is more of less clearance there the there should be. More likely though the nuts also could've come loose. On all the valve trains I do I use blue locktite even if it isn't called for because the last thing I want is those buggers to come loose because even at factory torque spec they do more often then one would think they should.
BIGef
Jul 6, 2012 10:17 PM
gsr96cx
18
Mar 15, 2009 04:02 PM
VegaS10
Oct 29, 2006 06:23 AM
gsrjay
Sep 2, 2004 05:05 AM
se93
Dec 12, 2003 01:45 PM
