Should radiator fan kick on as needed or anytime condensor fan is on?
Car: 95 civic dx
Prob: Air not cold during traffic or stopped
I have noticed that my radiator fan does not come on when condensor fan comes on. My car does not run hot, should the radiator fan kick on as needed or anytime the condensor fan is on
From: Pensacola, FL and every Court House in Louisiana
As needed. You propably just need to recharge the system with r-134. Depending on how low 20-30 bucks at part store
charge is weighed in at 20 oz. leak checked and put on a vacuum. it was working fine and then the compressor was kicking on and off, and then off completely(no compressor or condenser fan). My a/c psi switch is good, a/c comp. themo protector and the diode is good. Im not getting 12vdc to the comp now. it kicks in when jumped out. i also have 12v coming from the themo sw on yel-wht to the condenser relay.
I believe my condenser fan relay has gone bad, but my concern is could the relay on its way to complete failure cause the erratic a/c operation or something else.
also forgot to mention the light on the a/c button at the climate controls does not light up when pushed to the on position
Also check the wiring on the compressor, mine had a short for awhile.
i just switched the compressor relay with the condenser relay and now the system is working and cooling, im going to get 2 new relays
EGed up from the seat up
18
Jun 1, 2011 02:16 AM
