Transmission & Drivetrain Gearboxes, Differentials, Clutches
Z6 trans problem! help!?
Old Apr 1, 2012 | 08:32 PM
ProZack's Avatar
Icon2 Z6 trans problem! help!?
I have a D15B VTEC motor and just put a D16Z6 trans on it. 1st and 2nd are ok,, but 3rd the shifter jerks back and forward when giving it gas...4th won't stay in..5th does the same as 3rd. The car jerks in 3rd and 5th also. The throw-out bearing is shot,, could that cause this to happen? What all could it be? I don't know a thing about a tranny,, so I need some help please.
Old Apr 2, 2012 | 07:21 AM
h22steaksauce's Avatar
Default Re: Z6 trans problem! help!?
Good luck
Old Apr 2, 2012 | 11:41 PM
Mista Bone's Avatar
D Tranny Guru
sounds like a mount issue, did you a bolt or two out of the rear mount?
Old Apr 3, 2012 | 05:49 PM
95lsturbo's Avatar
mount issue perhaps. maybe the mount for the shifter itself. get under the car and shake stuff around. you may just see something obvious.
Old Apr 9, 2012 | 12:16 AM
ProZack's Avatar
Well from what I can tell it isn't a mount. Could it just be a bad tranny?
Old Apr 9, 2012 | 12:33 AM
eg6_trust's Avatar
Check your shift linkage it might be damage or you bushing that connects to the shift linkage to your shift **** try looking at that ...
Old Apr 9, 2012 | 01:46 AM
jmarshall098's Avatar
It's the throw out bearing definitely. Replace it and I am sure it will help you.
Old Apr 9, 2012 | 05:05 AM
MonkeyMagic's Avatar
not sure if serious..
tell harder.
Old Apr 9, 2012 | 05:09 AM
94EG8's Avatar
Seagull Management
No.
SisterFister
May 31, 2010 10:47 AM
Hatchman98
Mar 20, 2007 10:59 AM
91whiteZCrex
21
Sep 14, 2005 11:33 AM
KMK1605
Nov 18, 2003 06:19 PM
