b20 vtec head gasket change.. car wont start
Old Apr 1, 2012 | 06:47 PM
4doormob's Avatar
Icon2 b20 vtec head gasket change.. car wont start
i just replace head gasket on my db8 b20 vtec
double check all the connector n hose n everything is hook up right..
all it does is cranking n there a loud clicking noise but wont turn over...
what could be the problem?
Old Apr 1, 2012 | 07:10 PM
el crapitan's Avatar
Default Re: b20 vtec head gasket change.. car wont start
check your firing order. if that's correct, check for spark. if you have spark, check for fuel
Old Apr 1, 2012 | 07:11 PM
4doormob's Avatar
ill check the spark.
Old Apr 1, 2012 | 07:26 PM
4doormob's Avatar
check the spark.. spark is good..
when i crank it all my lights dim down..
could it be the battery or maybe no gas..
Old Apr 1, 2012 | 07:44 PM
charge up the battery.
and you checked firing order?
what about mechanical timing? you check that?
pull one of the plugs and see if there's fuel on it
did you remember to connect the thermostat ground cluster?
matter of fact, check/clean all your grounds
Old Apr 2, 2012 | 09:47 AM
kyden's Avatar
clicking noise? double check all grounds, make sure your battery is fully charged.
Old Apr 2, 2012 | 07:20 PM
4doormob's Avatar
i double check the ground and it was all good...
i listen to where the clickin noise was coming from n its sounds like it coming from the cly 4 area..
should i take it apart again n triple check on it or take it to a shop.?
Old Apr 2, 2012 | 08:27 PM
mouab18c1's Avatar
Is your mechanical timing dead on?
Old Apr 2, 2012 | 09:18 PM
4doormob's Avatar
i should check that.. i need a timing gun to do this..
Old Apr 2, 2012 | 09:19 PM
mechanical timing and fuel. check for both
Old Apr 4, 2012 | 12:01 AM
4doormob's Avatar
is check the fuel n its good.. i need to get a timing gun...
is there anyone from vallejo,ca that can help me out.. if so lmk
Old Apr 4, 2012 | 05:01 AM
you can't check ignition timing without the car running. you want to check mechanical timing. that is, the timing in relation to the crank and cams
Old Apr 4, 2012 | 10:28 AM
freaks_smk91's Avatar
put the engine at top dead center and pull the valve cover off and see if you have the valve timing correct. if it seems correct try spining your dizzy 180 degrees and reinstall.. just because ur ignition timing is off you car should start..just run like **** tho..
Old Apr 4, 2012 | 12:10 PM
4doormob's Avatar
okey ill be doing this tomorrow
Old Apr 4, 2012 | 12:15 PM
good luck
Old Apr 4, 2012 | 12:41 PM
4doormob's Avatar
thanks..
Old Apr 4, 2012 | 06:58 PM
b series distributor is notched so can't be installed 180* out
Old Apr 6, 2012 | 12:02 PM
4doormob's Avatar
okey well ima go work on the db8 today n see whats up.. ill keep updated..
Old Apr 9, 2012 | 10:31 AM
4doormob's Avatar
FAIL Project..
Old Apr 9, 2012 | 12:06 PM
wat happend?
Old Apr 9, 2012 | 07:09 PM
you did something silly didn't you?
out with it, boy!
salyboy25
Jun 7, 2011 06:10 PM
KingJeff
May 2, 2007 03:20 PM
ace42004
34
Apr 11, 2005 02:57 PM
johnjohn410
Dec 17, 2002 10:21 PM
B18C-RnVA
Oct 28, 2002 04:09 PM
