Break light switch
Old Apr 1, 2012 | 05:43 PM
Zac W.'s Avatar
Default Break light switch
Has anyone ever had one of these go bad? All of a sudden, I have no break lights. I have running lights and tail lights. Checked bulbs,
Both looked ok. I have a 99 LS
Old Apr 1, 2012 | 06:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: Break light switch
It's a switch, switches go bad all the time.
Unplug the brake light switch and jump the 2 leads, [most likely a white/green and a green/white] if the brake lights work, the switch is bad, replace it.
If brake lights still do not work, test for power on on the white/green, [input], if there is no powe,r check fuse and wiring to the brake light switch, if there is power, wiring from the switch, [green/white] to the brake light bulbs the bulbs themselves and the ground for the brake light bulbs. 94
Old Apr 1, 2012 | 08:00 PM
Zac W.'s Avatar
Ok will do. Thanks!
Old Apr 1, 2012 | 08:41 PM
imbest123's Avatar
what he said but before you do all this power testing check to see that the plastic piece that the button pushes against didnt break apart
Old Apr 1, 2012 | 10:21 PM
Zac W.'s Avatar
Ok. I check that too
Old Apr 2, 2012 | 06:00 AM
fcm's Avatar
fcm
Old Fart
If the "button" was gone, [broken] the brake lights would be on all the time. 94
Old Apr 2, 2012 | 02:57 PM
Zac W.'s Avatar
By turning the screw, do you mean the Allen screw? It looks like a Allen plug on the end, opposite end of where you plug into the iacv.
Old Apr 2, 2012 | 06:04 PM
fcm's Avatar
fcm
Old Fart
Say what???, the brake light switch is nowhere near the IACV, what "Allen" screw are you talking about??? 94
Old Apr 2, 2012 | 08:45 PM
Zac W.'s Avatar
Hahaha sorry wrong thread. I've got two going at once
hershy253
Jun 1, 2011 08:35 AM
atto
Feb 14, 2011 09:33 AM
XMANZREX
Oct 19, 2008 03:54 PM
wakaba_db1
Jul 8, 2005 12:44 AM
Enternal
Mar 29, 2002 05:36 AM
