Valve Cover Gasket
Old Mar 31, 2012 | 05:35 PM
cīvicus's Avatar
Default Valve Cover Gasket
So I'm going to spend some quality time with the newest car in the stable, and thought that I'd do a tune up (plugs, wires, rotor, cap [& cap gasket], fuel filter, air filter, oil change w/filter) while I replace the leaking valve cover gasket. Is there anything that yall can suggest that I should do at the same time?
Old Mar 31, 2012 | 05:39 PM
doood's Avatar
been there done that
Default Re: Valve Cover Gasket
Valve adjustment
Old Mar 31, 2012 | 05:48 PM
redm3turbo's Avatar
spark plug o rings
trans fluid
hows the coolant?
Old Mar 31, 2012 | 06:14 PM
cīvicus's Avatar
Valve adjustment is a bit much for me.
Spark plug o-rings are coming with the valve cover gasket.
Will tack on transmission fluid!
Coolant looks just as it did the day it was born.
Was looking into replacing the shifter bushings after all that.
Also wanted to throw ES poly bushings at the sway bar end links. Which brings to mind: What are the respective diameters for the front and rear sway bars for my '93 EX coupe? 16.8104 is the p/n I got for the front end links, but there wasn't one listed for the rear - forgive me, for I haven't looked and this is my first Honda, but, isn't there a rear sway bar?
Thanks for the suggestions!
Old Mar 31, 2012 | 06:52 PM
cīvicus's Avatar
Oh, one more thing - are there any brands that I would be better off without? For example, when I had Volkswagens, I'd always go for Bosch ignition parts and they worked flawlessly, however, when I had a Pontiac, Bosch were the scourge of all GM ignition systems.
In this case, I'm going with Bosch rotor, cap, and NKG plugs. Now, I could opt for the $42 Bosch plug wire set #09819, or the Standard Motor Products $25 set #7518 - a brand that I've never heard of, but seems to be favored at RockAuto (and closeout priced!).
Also that particular Standard Motor Products spark plug wire set, though coming up for my vehicle, indicates that it's geared toward the Si, but the set that is $1 more includes my SOHC VTEC motor - do all 1992+ Si's have VTEC?
Old Mar 31, 2012 | 08:35 PM
94EG8's Avatar
Seagull Management
As far as Honda's go stay far, far away from Bosch. OEM Honda plug wires will pretty much last the life of the vehicle. NGK wires are a pretty close second choice. I'd go OEM on the cap and rotor.
Old Mar 31, 2012 | 08:50 PM
cīvicus's Avatar
Thanks - I'll keep that under advisement. ...I could've sworn, though, that I saw a Bosch this-and-that under the hood the other day..
Old Mar 31, 2012 | 08:54 PM
Arthas's Avatar
Bosch is fine. I like to use NGK OE spec plugs with NGK blue wires.
All 92+ Ex and Si's have VTEC. Also the engines are identical.
I would recommend you do your distributor O ring and your manual transmission fluid.
Old Mar 31, 2012 | 09:55 PM
cīvicus's Avatar
Thanks for the information!
& in the latter portion, are you referring to the distributor cap gasket, or the internal o-ring mentioned here?==> https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-internal-seal-distributor-internal-oil-leak-2214402/
Old Mar 31, 2012 | 09:57 PM
Arthas's Avatar
Cap gasket.
Internal would also be recommend but im not sure if you would want to tackle something like that.
Old Mar 31, 2012 | 10:40 PM
TOO MUCH TORQUE's Avatar
since you're there, camshaft seal and maybe dizzy o-ring?
Old Apr 1, 2012 | 04:15 AM
cīvicus's Avatar
I thought that the camshaft seal was specific to the DOHC motors.
Old Apr 1, 2012 | 09:07 PM
jbpnoman's Avatar
Excuse you? This is wrong in so, so many ways.
Correct.
tjlewis10
Jul 8, 2017 09:38 AM
RaceMyGhost
Jul 7, 2006 11:03 AM
Accord2k-Hybrid
Jul 17, 2005 08:40 AM
tha Big EZ
Jan 13, 2004 04:29 PM
[HrZn]4life
May 13, 2003 09:30 PM
