d16y7 won't start -- weak spark
Old Mar 31, 2012 | 05:28 PM
BenDiesel76's Avatar
Default d16y7 won't start -- weak spark
i have a d16y7 that blew it's head gasket. I removed the head, had head resurfaced, pressure tested and a valve job. bought complete gasket kit and re-installed head. after getting the motor all back together, it will not start. I have checked and double checked timing, new plugs, but the FIRE seems weak? could the motor have gotten hot enough when the head gasket blew that it harshed the coil or other internals of the dizzy? the motor wont even backfire or anything, it makes no attempt to start. it has fuel and weak fire, please help
Old Mar 31, 2012 | 05:32 PM
Former User's Avatar
Default Re: d16y7 won't start -- weak spark
What color is spark? Is it bright white at all 4 spark plugs? A bad coil is a common cause of weak spark.
Stock Civic? Give details about your set up.
Old Mar 31, 2012 | 05:39 PM
1996 hatch, 1.6 non v-tec, stock bore, header. Spark is kinda orange on all 4. I know ur not supposed to but i even tried ether (starting Fluid) and got nothing. really is a stock car with new timing belt water pump cv's 180k miles automatic. Car just overheated badly on the highway when the headgasket blew, hauled it home.
Old Mar 31, 2012 | 05:40 PM
could the engine have gotten hot enough to hurt some other electronics?
Old Mar 31, 2012 | 05:43 PM
Resistance test it (see FAQs sticky).
Old Mar 31, 2012 | 05:57 PM
is the FAQs sticky the FAQ link u attached to your post? am reading through the faqs
Old Mar 31, 2012 | 05:59 PM
Yes (in my signature). Check Engine>Ignition System.
Old Mar 31, 2012 | 06:08 PM
will test more tomorrrow and let you know what happens. thank you for your help
Old Apr 1, 2012 | 01:40 PM
ordered new ICM today and new COIL, should be here wednesday. put new rotor button and wires on it today, but no luck. Although, when i first tried to start the civic it almost wanted to start but then nothing. so am thinking its the coil or ICM. i did tes the coil and ICm today and coil numbers looked off, ICM not so much, but gonna replace it anyway.
tchandarlis
Sep 6, 2016 09:33 PM
DumpdEJ6
21
May 25, 2011 11:31 AM
1wiperDude
31
Oct 13, 2009 06:46 PM
ddd4114
12
Jun 12, 2006 07:16 PM
riceburnah
Feb 15, 2003 10:07 PM
