1999 Civic Si Radiator Repair Questions
So, long time lurker here, and I've run into a problem I can't seem to find an answer to.
I'm in the middle of a radiator replacement, during which I was planning on replacing the lower radiator hose. I purchased and ordered the hose from Autozone, but when I got the part in-hand it appears as if it's 1-2/8th inch small in diameter than the stock hose. Am I missing something? Does the stock hose expand over it's life to be a bit larger? I can't get the new part onto the engine side no matter what I do (silicon grease/spray).
Has anyone had this issue before? Should I return and order the part oem from hondaautomotiveparts.com? Is there a trick to getting the hose on?
Thanks in advanced!
Thanks in advanced!
They gave you the wrong hose. Either bring it back and raise hell screaming and kicking or compare part numbers and nicely ask for the correct part like a sir.
3 post since 2006, yup, you're a lurker!
You shouldn't too much trouble with the return, I never have when there's been a mistake, especially when it's on their end.
Yea they will have ur bak bro. They have a decent rep fpr easy returns, like other dude said wen its their mistake the will usualy more than make up for it. Good luck!
Gsr94black
11
Jun 10, 2009 08:52 AM
mingbling96
Jun 1, 2005 08:19 PM
