Bisimoto 2.4 turbo Cam OVER Skunk2 Stage 2??
bisimoto makes some of the most over priced, under performing products on the market. Between the two id use the skunk2 cams, however I would give derek a call @ DDTECH and he could make you a much better cam for your setup, or at the very least, point you in the right direction.
give him a call sometime 1 225.384.1441 he helped me out immensely with my setup
Kool... Thanks Spawne... Just doing a lot of reading and research on this site.. Want to doing it right the first time and not cut any corners..I'll contact Derek
most of bisimoto's failings are posted in the all motor sub forum, just use the search for bisimoto and look for some of the dyno comparisons of his headers, or just call derek and ask him, he has first hand experience with it lol just tell him i sent you
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Well op. I'll post real facts on the cams instead of a bias opinion that never tried or used the product that your asking about.
The cam your asking about is a good cam. Its a web cam with bisi spec added. So your getting a quality cam. I used it with good results and will be going with the 3.6 on my brother build and I will be using the level x custom. I'll have results in a few weeks when we hit the dyno on his. Mine will be a lil longer due to personal things I want to do to my build. On the 2.4 the car made more hp and with lower psi then the skunk 2. So we were happy with the switch over. Call both companies and see what works for you. Just don't listen to a one side story. I like the quality of the bisi cam vs the skunk 2 imo. Looking at it side by side. Not saying the skunk 2 is bad.
