PG7 Wiring...HELP...
Ok. I need the MAP in for the PG7. Is it the white wire coming off the MAP, or one of the others? The wiring going in to the ECU is so F*ed up, I don't even want to deal with it there.
Also, the ICM. What color wire do I use for that. I'm thinking yellow/green, but what pin slot is it in? Does anyone have a diagram of this possibly?
Thanks,
jB
Thanks,
jB
FAWK
I installed the SMC/injectors, and now I can't run...
Problems:
I can get it started, but it wont idle. I can feather the throttle and it will choke and die after a couple seconds. I'm throwing code 15 (Ignition Output Signal), and it wont run...
AWWWWWWWHHHHHHHHHHHHHHHHHHHHHH
jB
Problems:
jB
