92 civic overheating
Old Mar 30, 2012 | 04:02 PM
cloudystar83's Avatar
Icon2 92 civic overheating
Got a 92 civic hb, 200k. Replaced the thermostat and gave it a tune up. Still overheats when sitting too long, or in the mountains. I add antifreeze at least 2-3 times a wk. I drive it daily. Don't think it is the head gasket cause wouldn't the coolant/oil be mixing? The fan does turn on. What else could be the problem, not wanting to replace the head gasket if I don't have to.
Old Mar 30, 2012 | 04:42 PM
Mr. EG's Avatar
Default Re: 92 civic overheating
Perform a cooling system pressure test to check for leaks.
Old Mar 30, 2012 | 04:57 PM
Cmoya07's Avatar
why is it using up so much anti freeze??? a leak or bad radiator is my guess
Old Mar 30, 2012 | 05:34 PM
dlstech's Avatar
Is it leaking onto the ground at all? If so, find where it's coming from. If not, it's probably the head gasket so do a leakdown test to confirm.
Old Mar 31, 2012 | 07:35 AM
Not finding any on the ground, how do you perform the pressure test? If it was the head basket wouldn't the coolant and oil be mixing?
Old Mar 31, 2012 | 07:57 AM
Safety_Driver's Avatar
Did you properly bleed the system after the installation of the termostat?
It has nothing to do with the leak, I'm just asking.
Old Mar 31, 2012 | 08:50 AM
dlstech's Avatar
Doesn't always mix with the oil. I could go straight to the cylinder and burn off. And white smoke/steam out of the tail pipe?
beat ignition
Honda Civic (2001 - 2005)
Jun 7, 2019 04:24 AM
niceprelude
Dec 21, 2014 08:05 PM
syvlvr
Nov 19, 2012 04:11 PM
MarkM01
Apr 10, 2011 04:21 AM
azz_kicker
Apr 16, 2006 04:59 PM
