Tire size in relation to 1/4 mile time & MPH
Old Mar 30, 2012 | 01:41 PM
vtak2nr's Avatar
Default Tire size in relation to 1/4 mile time & MPH
I'm just wondering something. I am an occasional track(drag) racer and here's the situation i am in
I have a '98 civic coupe swapped in a JDM B16A
Last year I ran a best time of 14.8 @ 92MPH
Over the winter I pieced together a trubo kit and had a friend start and a garage finish + tune my car. It's only street tuned for now, @ 7psi will a t28 turbo
I went to the track first time this season a couple nights ago and ran a dissapointing 14.8 @ 98mph (well, everyone ran a bad time, it was below freezing out)
Now I know you can tell by my time and trap that I am spinning too much. First gear, regardless of how soft I launch or how I feather the pedal, it's just spins like crazy. Going into 2nd, it just it'll spin till about 60-65mph before it catches
Now here's where my tire situation comes in. Right now I have some no name (and probably chinese made) tires, 205/40R17. I was looking into getting 2 Falken Azenis for the front, but then I was thinking are the rims too big?
If putting falkens on my 17's isn't a good idea, what would the ideal tire size be for max grip, and with this size, will my MPH be higher? Would it be higher if I spun less with better tires?
Pretty much what im asking is, will the MPH//ET difference be sufficient enough to warrant smaller tires, or will I be fine with the 205 40 17
Thanks for any input
Old Mar 30, 2012 | 03:21 PM
eg6-jarhead's Avatar
Default Re: Tire size in relation to 1/4 mile time & MPH
mph wont change much. you need more boost! 7psi is too low to run good times.
slicks would be the best maybe a 23x8x15
next would be some drag radials 205/50/15 (just get some cheap steelies and throw them on at the track.
for a true street tire i hear that the nitto neo-gens are the best. they are pretty cheap too and available in a lot of sizes.
you trap speed is the same as my first turbo setup...but i was using a d15b7 with a t25 on 8psi. i went 14.6 @ 98mph withg 205/40/17's. you need more power!! are you sure it was tuned right?
Old Mar 30, 2012 | 03:32 PM
95dxsir2's Avatar
i would get some slicks if you want to see how fast it will go...street tires and drag radials will not do any justice. and why only 7 psi out of a baby turbo....turn that **** up.
i don't see why people use street tires on a turbo car...bragging rights? ego? dumb ***? not enough money? get some slicks, turn the boost up on a reputable tune...and run that ish.
Old Mar 30, 2012 | 03:37 PM
Garage 808 Hatch's Avatar
you only gained 6mph in the 1/4 with a turbo kit?
Bored&Stroked
May 14, 2013 07:02 AM
RyanEJ8
Mar 7, 2006 05:06 PM
Inprogress
Mar 8, 2004 07:32 PM
93civdx
Nov 15, 2002 01:25 PM
