B18C1 Rod Bearings Re-Used
Old Mar 30, 2012 | 09:47 AM
Omegax10's Avatar
Default B18C1 Rod Bearings Re-Used
Ok so I purchased a b18c1 gsr block oem rebuilt with acl race bearings. Problem with the block is 3 of the head studs were helicoiled previously since they were stripped due to incorrect head stud install. I purchased a different GSR block that had a spun bearing and was planning on installing the internals from the first block with ACL Bearing (Crank and all) into the block that had the spun internals. I was wondering if I Could reuse the ACL bearings from the first block since I am using the same internals they were attached to???
I am planning on honing the new block and using new piston rings or maybe upgrading to p73 pistons to bump compression also
Old Mar 30, 2012 | 10:00 AM
JDM_teh_WIN!!'s Avatar
Default Re: B18C1 Rod Bearings Re-Used
The main concern would be the condition of the bearings and checking the clearances. I would not suggest just swapping the bearings without at least plastigauging them.
Old Mar 30, 2012 | 10:04 AM
pityocamptes's Avatar
Why hone? If you have the block out do it right and have it bored. Honing is a fast a dirty way of doing a rebuild, but usually just done to get a daily driver by, especially when the vehicle needs to be done quickly and the block is still in the car.
Old Mar 30, 2012 | 10:28 AM
kyden's Avatar
not really. if the walls are true, there's no reason he should have to bore.
Old Mar 31, 2012 | 12:11 AM
jbpnoman's Avatar
Just plastigauge the bearings. If they're within spec, you're good to go.
frisbie21789
Jun 22, 2011 04:26 AM
Non-Vtec101
May 1, 2011 11:14 AM
mountaindewguy
Oct 18, 2006 10:13 AM
preludesi93-arg
Jan 1, 2005 08:30 PM
ubreak_ubuy
Apr 28, 2004 10:12 AM
