Has anyone had a CUSTOM turbo manifold made for an EF???
Old Mar 30, 2012 | 02:20 AM
4door89's Avatar
Default Has anyone had a CUSTOM turbo manifold made for an EF???
Just curious to see what you guys are running, Im thinking of having a custom manifold made that positions the turbo as close to the drivers side as possible, so i can have plenty of space for a 3" and do a backdoor setup.
Old Mar 30, 2012 | 05:42 AM
wreckin-rex91's Avatar
Default Re: Has anyone had a CUSTOM turbo manifold made for an EF???
I have a PFab manifold with the WG dumping to passenger side. Lots of room in there and I am basically running the IC pipe backdoor. My turbo is a Garrett 57 trim and there is just enough room to run a Civic 1/2 radiator with no clearance issues. I can shoot you a pic if you want.
Old Mar 30, 2012 | 11:22 AM
shiroun's Avatar
Yes.
If I were you, I'd do it yourself (which is what I'm doing now. Making a dual side exhaust for my b18 with a 4-2-2 header, and then getting another 4-2 exhaust manifold and making a custom turbo manifold out of it).
It isn't too complicated. If you have a belt sander and a metal sander (i think thats what they're called), and a welder, you can do it. Just takes time.
Old Mar 31, 2012 | 01:36 PM
th3pwn3r's Avatar
http://i60.photobucket.com/albums/h1...i/5a2840cf.jpg
Like that?
Old Apr 8, 2012 | 09:19 PM
4door89's Avatar
That last pic is a little too intense. I just need a t3 38mm manifold. Im about to have one made for about $500-600.
Def want enough space to be able to run a 3" downpipe (up pipe), up through the hood, as well as a normal exhaust.
Send me pics please!!!
Old Apr 9, 2012 | 10:06 AM
TheShodan's Avatar
Moderator
Pick one or the other. Can't do both.
Old Apr 9, 2012 | 08:41 PM
artie89's Avatar
hit up brms they make custom manifolds for ef
Old Apr 10, 2012 | 07:50 PM
4door89's Avatar
With a v-band i'll do what ever i want damnit. BE LEE DAT KNEE GROW!
Custom made radiator, nice! Super space!
Old Apr 10, 2012 | 07:53 PM
tjdmcoupe's Avatar
If you have a FB page look up H&H fabrication. They build some bad *** all custom parts. Turbo manifolds/Headers/intake manifolds. They pretty much do it all
Old Apr 10, 2012 | 07:57 PM
TheShodan's Avatar
Moderator
Old Apr 11, 2012 | 11:39 AM
slywfbpsi's Avatar
http://www.boostwerks.com/products/e...mount-manifold
Old Apr 11, 2012 | 12:47 PM
SovXietday's Avatar
Hahahaha. x2.
Old May 29, 2012 | 08:39 AM
4door89's Avatar
this is where the turbo is going.
Old May 29, 2012 | 08:55 AM
raene's Avatar
How does the oil drain line look way down there.
Old May 29, 2012 | 02:38 PM
4door89's Avatar
eh. its ok, not as ideal as i would like, but def above the drain.
Old May 29, 2012 | 04:06 PM
SovXietday's Avatar
Gonna have to clock the turbine housing toward the rad support more, otherwise you will never be able to connect the runners closest to the block. Been there, done that.
Also, mind your dipstick.
ballinthavx
Oct 4, 2010 09:24 PM
veejay
Sep 5, 2001 07:49 PM
