front damper fork question
Old Mar 29, 2012 | 05:40 PM
swizz977's Avatar
Default front damper fork question
when you put the front shock in the damper fork.. how does it go on? can you slide it to any position you want?
Old Mar 29, 2012 | 07:58 PM
Strangerover's Avatar
Default Re: front damper fork question
I believe that the shock has a protrusion on it that lines up with the "split" in the top of the fork. If not, it doesn't matter. You do have to assemble the shock/spring/upper plate so that the threaded studs line up with the holes in the top of the shock tower, and the fork lines up w/ the axle.
Old Mar 30, 2012 | 04:49 AM
swizz977's Avatar
well i was just wondering if you can put the shock in lower so the car will sit lower
trepteg
Honda S2000
Apr 3, 2010 09:26 AM
todd bayliss
Suspension & Brakes
Sep 26, 2009 09:39 PM
alexm
Suspension & Brakes
Aug 23, 2008 07:56 AM
wildstallion
Jul 12, 2003 07:39 PM
