d16zc low rpm sputter
Old Mar 29, 2012 | 02:11 PM
GPC91's Avatar
Default d16zc low rpm sputter
hey i have a d16zc out of a 95 civic in my 90 crx. i know im not posting in the crx section but i figured since the engine comes from 95 i should post here.
my car run perfectly fine when the tank is above about half full sometimes down to 1/4 but after that it sputters and bogs down extremely bad at lower rpms. if i keep it above around 3000 im fine but i know its not good to drive when something is wrong. i was told this could be the map sensor but figured it would be good to ask to get some more opinions before i go and buy parts.
also i do not throw any codes
thanks in advance
Old Mar 29, 2012 | 08:58 PM
Alpha Q 2.0's Avatar
Default Re: d16zc low rpm sputter
Yes
Map, TPS or maybe even the IACV
Old Mar 30, 2012 | 01:08 PM
GPC91's Avatar
alright thanks. and just curious. i know it isnt great to run with something wrong but if i keep the gas near full and it isnt acting up is it ok for me to drive it untill i get the part and time to replace it
Old Jun 15, 2012 | 01:10 AM
cklauj207's Avatar
Hey did u ever get this fix? im having the same issue with my 89 CRX si with a ZC block..
lordbobb
18
Jan 9, 2010 10:52 AM
Pekkaen
Feb 20, 2007 01:09 AM
baked_beanz
Feb 12, 2005 04:40 PM
ce
Jun 24, 2002 09:31 AM
