p1297 and p1298
Old Mar 29, 2012 | 01:42 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default p1297 and p1298
96 dx with a jdm b16a
All of a sudden I started throwing these codes but my CEL light won't go on. I unplugged my o2sensor and the CEL went on for that but I continue to get these codes. I found them after a trip to emissions and my system monitors were not running. everytime I turn the car off and then back on the obd2 monitors reset. Any ideas?
Old Mar 29, 2012 | 01:50 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: p1297 and p1298
What ECU?
Old Mar 29, 2012 | 01:56 PM
doctorake's Avatar
Community Builder
P2T
I did the CFK trick no issues
did the FTP trick no issues for a while now if I up or lower the 2.5v going to the ECU I still do not throw a CEL code however.
I also just checked my engine gorunds and they were good
Old Mar 29, 2012 | 02:15 PM
Technical Hero
Check all your underhood and dash fuses
Old Mar 29, 2012 | 02:17 PM
doctorake's Avatar
Community Builder
all fuses were ok, starter signal was blown but i replaced it and it did not re blow nor has the issue resolved
whoever started the swap did not connect the ELD to the other end of the jumper harness I am using, resetting ECU now and seeing if that works
Old Mar 29, 2012 | 02:21 PM
doctorake's Avatar
Community Builder
Still throws the codes, it will throw 1297 after I clear them before I even start the car. Just the key in the on position throws it
Old Mar 6, 2020 | 01:52 PM
TuroM's Avatar
Did you ever figure out what the problem was? I have the same issue with my 96 civic lx. I have the P1297 code and i went down the troubleshooting methods on the manual. The ELD connector has 3 prongs and apparently one is supposed to have 4.5 volts when tested with a multimeter but mine doesnt. Could it be the wire itself that has been shorted and is there a way to tell? How hard would it be to actually remove that wire from the eld connector and ecm connector? I know the whole wiring goes through a hole and comes out where the fuse box is at but man it looks super complicated.
marcwinters
Nov 7, 2013 02:31 AM
BuiltCivic99
Aug 28, 2009 03:11 PM
liquidxEG
Feb 22, 2005 03:46 PM
crvtt96
Jun 6, 2004 04:00 PM
Formula 1
Sep 14, 2003 06:22 PM
