Ferrea valve spring advice for turbo application?
Old Mar 29, 2012 | 08:25 AM
4cylfiend's Avatar
Default Ferrea valve spring advice for turbo application?
Just needed some advise from some of you that are running Ferrea valvetrain in your race engines.
I'm in the process of getting parts together for my build this season and I have decided on going with a full Ferrea valvetrain setup. I'm talking valves, spring seat locators, valve springs, retainers, valve locks, the whole 9.
My hang-up is trying to figure out what part number of spring I should be running. Ive searched and really cant find any useful info on this.
I'm running Skunk2 Pro1 cams in my head and it looks like the Ferrea part number of the valve springs that I need to use is S10064. Is there any guru's on here that can confirm this for me?
Specs on these springs are:
Seat pressure- 95lbs
Open pressure- 215lbs
Rate/inch- 305lbs
Coil bind- 19mm
Max net lift- 14mm
Thanks in advance guys.
Old Mar 29, 2012 | 09:10 AM
heavy duty's Avatar
Default Re: Ferrea valve spring advice for turbo application?
I called them about the pro 1s and gave them the spec of those cams and they told me the part number of the springs i needed was s10027.
Old Mar 29, 2012 | 09:21 AM
4cylfiend's Avatar
Ya I looked at that part number but wasnt sure about them because on the Ferrea site it listed the S10064 as a "Turbo" application.
Old Mar 30, 2012 | 01:31 AM
4piston's Avatar
Jit...run the heavier spring
Old Mar 30, 2012 | 04:24 AM
4cylfiend's Avatar
Are you talking about the s10027 springs Luke?
The specs of the 2 springs (s10027 and s10064) differ but would it be just as simple as going with the heavier spring?
S10064
Rate/inch- 305lbs
Coil bind- 19mm
Max net lift- 14mm
S10027
Seat pressure- 100lbs
Open pressure- 220lbs
Rate/inch- 305lbs
Coil bind- 20mm
Max net lift- 13.5mm
Old Mar 30, 2012 | 04:37 AM
4piston's Avatar
Neither. I'll be back in the country Tues/Wed give me a call and I will show you which springs. I have them at the shop.
Old Mar 30, 2012 | 05:10 AM
4cylfiend's Avatar
Word. The next size up that they have is the S10086 which says "This spring requires Ferrea Roller Rocker #RR1000"
Luke, what are you trying to get me into?!
Old Mar 30, 2012 | 05:29 AM
Zer0_SpeedWorks's Avatar
using pro1s too with sk2 spring and rets
but most of the guys who has custom webs and pro1s suggest and are using the ff ferrea stuff
Valve spring - S10027
Retainers - E11000
Old Mar 30, 2012 | 05:50 AM
4cylfiend's Avatar
Originally Posted by Zer0_SpeedWorks
using pro1 too with sk2 spring and rets
but most of the guys who has custom webs and pro1s suggest and using the ff ferrea stuff
Retainers - E11000
Thanks for the input! How long have you been running the Pro1's with the s2 springs and retainers? What are the specs of the springs you are running? My plans are to mainly run my car at the track, but I will drive it around town on the weekends. I just dont want to induce alot of valvetrain wear if I can avoid it. I plan on keeping it below 800whp.
Old Mar 30, 2012 | 06:00 AM
around 2years with minimal street time on 800-900+whp
was asking around too regarding the part nos. for ferrea stuff cause im planning to upgrade to together with a custom webcam.
Old Mar 30, 2012 | 06:16 AM
4cylfiend's Avatar
Awesome. Thats really good at that power level. I have been told not to use s2 prings and retainers but it seems that there are alot of people having good luck with their valvetrain products. What do you rev it out to? I just dont want to float a valve but if you have had good luck with it for 2 years, you are doing something right.
I venture to say that eventually I'll run a webcam setup with roller rockers but for now I just want to get the car together and make it last to where I can learn how to drive it
Old Mar 30, 2012 | 07:05 AM
im planning on using standard custom grind webcams not the rollers ones...
revving it up to 9800-10k
if i can do it all over again, i will go straight with ferrea...
Old Mar 30, 2012 | 08:34 AM
tepid1's Avatar
Web does not make roller cams.... FYI
Go web and never look back.
Old Mar 30, 2012 | 10:15 AM
nonvtecallmotor's Avatar
I went Web and went backwards....
Old Mar 30, 2012 | 10:24 AM
4cylfiend's Avatar
Uh oh.
Old Mar 30, 2012 | 11:50 AM
tepid1's Avatar
Good for you. Smh
Old Mar 30, 2012 | 12:22 PM
Good for you. Smh
I speak from experience. Something you know nothing about.... I (Unlike you) have REAL TRACK DATA.
Old Mar 30, 2012 | 01:30 PM
tepid1's Avatar
All hail Rick!
SMH
Old Mar 30, 2012 | 10:24 PM
SMD..
Old Mar 31, 2012 | 04:57 AM
hello1320's Avatar
SMD....Lmao !!!!
Old Mar 31, 2012 | 06:05 AM
Boost_allways's Avatar
Hey guys, i have WEB Pro series cams for B18C. Which valves, springs + retainers, locks & valve seals are best to use with these cams ?
Old Mar 31, 2012 | 09:13 PM
99black_em1's Avatar
do u mind sharing your experience with Web, and what you use instead now?
Old Mar 31, 2012 | 09:29 PM
hello1320's Avatar
Stock camshafts
Old Apr 2, 2012 | 06:52 AM
4cylfiend's Avatar
Does anyone else have any input on which Ferrea springs will best suit my application?
Old Apr 2, 2012 | 11:20 AM
I'll just say that stock cams out performed them BY a mile in everyway possible..
Originally Posted by hello1320
Stock camshafts
I have not run stock cams in a while. I did run Pro1's (should of tryed Tuner2's) for a while and they are by far a better choice over the Webs. Even thought they are bigger then the Webs they spooled better and made alot more power. Just an over all better choice..
For this year I stepped out side of the box alittle to try something that I've learned from testing a bunch of different cams.. So far I'm quite pleased with the results but, I only have a hand full of passes on them now. Only time will tell.
89efhatchy
Mar 12, 2014 08:49 AM
monster_c
Jun 5, 2012 12:32 PM
4cylfiend
Apr 4, 2012 07:04 AM
Skunk3
Jul 23, 2009 04:32 AM
TRuST
Sep 2, 2004 03:29 PM
