Aero Wheels and Slicks?
Old Mar 28, 2012 | 07:26 PM
88crxvtec's Avatar
Default Aero Wheels and Slicks?
I have an 88 crx with Integra LS brakes and was thinking about ordering Aero wheels from summit and some slicks. Anyone use them?
Old Mar 28, 2012 | 07:50 PM
Dan@DFR's Avatar
Default Re: Aero Wheels and Slicks?
x2 also intrested
Old Mar 29, 2012 | 05:10 AM
SPOOLINmatt's Avatar
they are a little porky
Old Mar 29, 2012 | 06:10 AM
Martian's Avatar
They are a good cheap steel wheel. I had some for a season, then sold them to MX6er who used them for a season. Can't complain for the price.
Old Mar 29, 2012 | 10:20 AM
88crxvtec's Avatar
Will I need a spacer? Extended studs?
Old Mar 29, 2012 | 10:41 AM
Martian's Avatar
Depends on the offset you choose
Old Mar 29, 2012 | 03:36 PM
88crxvtec's Avatar
What offset would be best on a CRX with DA brakes?
Old Mar 30, 2012 | 11:00 AM
welfarepc's Avatar
somewhere right around 0et in an 8" wide wheel will clear most all slicks
you could go with a +25 if u were looking to rock smaller slicks like 22x8x13s or 23x8x13's
the 24's will hit the knuckle with a +25 they need about an inch more to be safe, IMHO.
Old Apr 2, 2012 | 05:11 PM
FIST321's Avatar
diamonds are cheap and they will build u anything u want
Old Apr 2, 2012 | 07:10 PM
Garage 808 Hatch's Avatar
Some of these steel wheels regardless of back space will not clear Honda brake calipers due to the design of the center, without a spacer. The way they transition from the hub to the barrel they do not offset it with enough angle or a curve to get out and around them.
Old Apr 2, 2012 | 10:41 PM
artie89's Avatar
the aero space wheels will not clear integra brake calipers you will need a 1/2 in spacer or shave down the calipers if you order some make sure that they or 4 x 4 bolt pattern 4in backspace with whatever width you want here is a picture of them on my bother car
Old Apr 2, 2012 | 10:53 PM
artie89's Avatar
here are some pictures of some on a integra
HondaH22a#1
Feb 10, 2010 04:23 AM
GSRinmyCRX
Jan 27, 2010 10:28 AM
dunkd
Jun 6, 2005 12:01 PM
caLiH22A
Jun 16, 2004 12:12 PM
