Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch pedal gets soft !!! need help
Old Mar 28, 2012 | 12:27 PM
bigdem1civic's Avatar
Default clutch pedal gets soft !!! need help
i have a 2000 civic with an h23a and a h22 tranny 5 speed lately in the mornings my clutch pedal is soft and i have to pump it to get it to go into gear. once im driving it works fine but when i stay on a gear for a while or im on the highway clutch pedal gets soft again . i have to keep pumping it every once in a while in order for it to work. i changed the master cylinder it worked fine for 5 days no problem. i thought i solved the problem, i bleed the clutch fluid, and still same problem and when i did the swap a month ago the slave cylinder was changed to wut else could be the problem ive been like this for two weeks now...
Old Apr 5, 2012 | 12:25 PM
Motox122jk's Avatar
Default Re: clutch pedal gets soft !!! need help
Re-bleed the clutch.....sounds like there's still an air bubble
Old Mar 13, 2014 | 10:09 AM
Jesi1904's Avatar
I have the same issue, but I also have to add fluid every 3-4 days I have only replaced the Master whats next?
Old Mar 13, 2014 | 05:50 PM
Mista Bone's Avatar
D Tranny Guru
find the leak.
bb62o3
Sep 28, 2009 12:46 PM
civicandr6
Mar 16, 2007 07:18 PM
importfanatic17
Jan 1, 2007 10:00 PM
Drizzo
13
Aug 5, 2004 08:44 AM
JLange
Mar 31, 2003 05:53 PM
