Running to RICH
Old Mar 28, 2012 | 12:22 PM
Accord(ing)2me's Avatar
Icon2 Running to RICH
What can I do to lean out my Accord
Old Mar 28, 2012 | 12:26 PM
JuggerNaut-CTR's Avatar
Default Re: Running to RICH
Why is it running rich?
Cel?
What ecu is in the car?
Old Mar 28, 2012 | 07:37 PM
Hidenplanvew's Avatar
how do you know if your running rich?
Old Mar 29, 2012 | 10:51 PM
MAD_MIKE's Avatar
MM Gruppe B
Year, sub-model? Any modifications? How do you know it's running rich?
Start with the basics, check for strong spark, correct timing, leaking gaskets, etc etc.
Old Mar 30, 2012 | 11:14 AM
scmil95eg's Avatar
1) decrease values in fuel map
2) decrease fuel pressure
3) install smaller injectors
4) introduce vacuum leak (must have open loop fueling)
Old Mar 30, 2012 | 01:02 PM
J.Hutch90's Avatar
i installed a cold air intake on my accord, causing it to run rich, had to re-map the ecu for correct air/fuel ratio
Old Mar 30, 2012 | 01:38 PM
GhostAccord's Avatar
Nice story!
Old Mar 30, 2012 | 02:21 PM
Rusty_hoock's Avatar
How do you re-map ECU¿
dglassmyer's Avatar
Ehh, indeed Ghost, I too am beginning to smell something a little off in here, but what could it be...
Old Mar 30, 2012 | 02:26 PM
As far as I know there really isn't any way to remap a stock Accord ECU. However, you can reset it by pulling the backup fuse or disconnecting the (-) battery terminal for 30-60 seconds. This will set the ECUs short & long term fuel trims back to base/0.
lol...
Old Mar 30, 2012 | 02:30 PM
lol...
Thanks from the nOOb
Old Mar 31, 2012 | 12:46 AM
MAD_MIKE's Avatar
MM Gruppe B
roflwaffles anyone?
Installing a CAI will not cause your car to run rich.
Completely screwing up the install, which would be a feat, might cause the car to run a little off and smell slightly better than your butt after a night out drinking Guinness and eating Wienerschnitzel.
HondaMan2380
Sep 21, 2010 03:39 PM
maxamusprime
Jan 21, 2007 02:30 PM
turbo-d
Feb 4, 2005 04:58 PM
mario82686
14
May 7, 2004 09:11 PM
ddua
Oct 4, 2003 10:08 AM
