Is it expensive for a normal track day?
Depending on the thread depth your tires will easily last you more than a few laps. I haven't personally tracked on some of the newer stickier compound tires yet. But I believe I did around 6 weekend (2 day) events and a decent amount of street miles on my Falken Azenies RT-615. However, with most tires that you will pickup you should have no problem getting quite a few events on them.
Other things to prep is to upgrade:
- Brake fluid (ATE Superblue or Motul RBF600). Note, that you should bleed your brakes and do a flush more often than stock fluid as brake fluid is hygroscopic and absorbs water/moisture from the air.
- Brake pads - you can just get a dedicated set of track rotors and pads or even just pads for track duty. These will also last you a decent amount of events.
Otherwise, just make sure your car is mechanically sound, purchase a helmet and you are good to go.
Ali
Ali
I'll get 15ish events out of a set of RE-11's
did 2 track days on RT-615's
didnt changes brakes or pads for my first event and brakes were done after the 3 or 4th session, on my second event i got new pads and rotors and they were good through 5 sessions!
Rain_man
Jun 24, 2002 11:52 AM
