B18b swap for '88 honda crx HF
Old Mar 27, 2012 | 08:35 PM
JuSt4KiCks's Avatar
Default B18b swap for '88 honda crx HF
Hey there! Planning on swapping out stock engine and tranny on my '88 CRX HF with a B18b engine and new tranny, was wondering if any of you guys have any advice or tips to help me out? Or if I'll encounter any future problems with the swap.
Old Mar 27, 2012 | 09:18 PM
KINGVEM^^ED6's Avatar
Default Re: B18b swap for '88 honda crx HF
Search brah its been done
Old Mar 28, 2012 | 10:16 AM
EFnCRX's Avatar
you will need dx/si hubs for sure
Old Mar 28, 2012 | 11:16 AM
EFnCRX's Avatar
Old Mar 28, 2012 | 01:50 PM
JuSt4KiCks's Avatar
thanks for your somewhat helpful advice, I'll keep looking around and hopefully find some useful info
Old Mar 28, 2012 | 08:32 PM
delsol92's Avatar
you will need b series ef mounts(inivative will clear the hood)
b series ef linkage
b series axles, halfshaft, dx or si hubs(remove the dust ring in the back)
if you use a hydro tranny you will have to convert to hydro
if you use the b1 injectors you will need to remove the resistor box
beat in the frame rail for the altenator
obd0 ecu and distributor unless your obd1 then obd1 ecu and distributor with ecu and distributor jumpers
thats all that i can think of for now
Old Mar 30, 2012 | 09:21 PM
JuSt4KiCks's Avatar
Thanks! Just the info I was looking for!
Old Mar 31, 2012 | 04:43 AM
Spug's Avatar
Read this first:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old Apr 3, 2012 | 05:14 PM
JuSt4KiCks's Avatar
Do these also apply for a B16 engine??
Drew17th
Oct 30, 2005 01:18 AM
enve55
31
Oct 16, 2005 05:32 AM
andwrong
May 5, 2003 04:20 PM
civicmark
Sep 30, 2002 05:36 PM
cjfinkle
Jul 17, 2001 09:53 PM
