HELP! fuel pressure regulator and fuel rail install?
what type of stuff should I clean my injectors and their holes with and do I need any new seals? Is their anything I should go easy one because I've never done this before. Thanks!
get a helms manual and it'll show you just want you need to do.
make sure to relieve your fuel pressure before you start.
put an oil coating on the injector O rings
don't over torque your fuel rail down
take your time
take your time
Relieve fuel pressure by taking off the gas cap.
There is going to be fuel leaking/spray when you take the line off the rail so have some rags or something to catch it.
The new fuel rail should have came with new injector O-rings. Make sure you oil them down first and the slide them onto the injectors.
When you take apart the fuel rail dont forget how the washers go on at the end of the fuel rail.
The hardest part for me was getting the fuel rail to seal at all the washers. You should use liquid teflon at most of the areas to seal the bolts. At the end bolts of the fuel rail I had to use teflon tape. The liquid teflon didn't make a seal.
It is fairly simple, just take your time.
Stevemyster
Jun 5, 2011 06:49 PM
Bantam
Mar 7, 2003 08:58 AM
