HELP! header GLOWING!!!!!!!!!!!!!!!!
Old Mar 27, 2012 | 03:51 PM
slimmy502's Avatar
Default HELP! header GLOWING!!!!!!!!!!!!!!!!
Hey guys, i just did an ls swap in my ej8 and i have everything ready to go but my header is glowing!
please tell me what could cause this. Motor is in time and valve adjustment was done 4 days ago. i have not driven the car, its still on jack stands.
Old Mar 27, 2012 | 03:52 PM
grumblemarc's Avatar
The Grumpiest
Default Re: HELP! header GLOWING!!!!!!!!!!!!!!!!
Correct me if I'm wrong somebody but that is a prime indicator that you are running extremely lean. Check your timing.
Old Mar 27, 2012 | 04:15 PM
KoNEY's Avatar
LEAN.
Check timing and fuel pressure. Also pull the plugs and take a pic of the tip.
Old Mar 27, 2012 | 08:17 PM
slimmy502's Avatar
Motor is in time. So what am I looking for at the tip of the plugs? And if I'm not running the correct fuel pressure what could be my possible problem(s)
Old Mar 27, 2012 | 08:29 PM
jbpnoman's Avatar
Yes, not running the correct fuel pressure could cause a lean condition. Pull the plugs, take a picture, and post it.
Old Mar 27, 2012 | 08:31 PM
slimmy502's Avatar
I will take a picture and post it tonight when I.get off work so those of you telling me to do so please check back ASAP. I'm just wondering what I'm supposed to be looking for at the tip and what my possible problems could be if it is running lean.
Old Mar 27, 2012 | 08:59 PM
jbpnoman's Avatar
I'll be here all night
Old Mar 27, 2012 | 09:00 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
What ECU are you running?
Old Mar 27, 2012 | 09:08 PM
Cmoya07's Avatar
lol its kryptonite!!! j/k i dont know i will keep checking until this gets solved im interested to see what it is
Old Mar 27, 2012 | 09:57 PM
KiDDD...'s Avatar
that ish looks dope, I'd leave it like that bro.
i kid i kid. Your running lean, badddd.
Old Mar 28, 2012 | 02:13 AM
slimmy502's Avatar
i am running an obd1 automatic ls ecu. As requested though here are the pics of the spark plug ends
plug 1
plug 2
plug 3
plug 4
all four plugs if you can't see are whitish at the tip which I know is an indicator of it running lean. Btw guys and possibly girls, i appreciate your help and input. I miss driving this thing and im ready for her to be back on the road!
Old Mar 28, 2012 | 02:17 AM
jbpnoman's Avatar
Double check your timing, and attach a fuel pressure gauge to your fuel rail. Tell us what it reads. Does the car idle normally? Are there any CELs?
Old Mar 28, 2012 | 02:28 AM
slimmy502's Avatar
there are cel's but im not running an o2 sensor and dont have a code reader for the obd2 harness. I don't really understand timing yet, so explanation on that may help me understand what to look for. All I know is that both cams are TDC and that i need to find the sweet spot with my dizzy timing. The idle is shitty, it wants to fall on its face so to say for the first minute or so, real shaky. I assume that this could be caused by it running as lean as it is, just not enough fuel so it doesn't want to stay started, perhaps? I'm also not sure of what octane fuel I'm supposed to be running in an ls, I'm running regular 89 octane, could that perhaps make it not burn enough fuel? ECU is untouched as well.
Old Mar 28, 2012 | 02:30 AM
slimmy502's Avatar
It also doesn't want to start the first key turn, and barely wants to start on the second key turn but it does usually start upon second turn of the key.
Old Mar 28, 2012 | 03:04 AM
jbpnoman's Avatar
Three things for you to do. Do them in order, and let us know what the results are.
1: How to check for CEL codes
Pull your code. That process still works for OBD2 cars, IIRC - you don't need a code reader.
2: Fuel Pressure ('97 and later models) (Service Manual)
Test your fuel pressure. If it is below 40PSI, stop here.
3: Ignition Timing Adjustment
Ignition Timing and Inspection (Service Manual)
Follow the link above, as well as the image linked above, to help you verify timing.
Old Mar 28, 2012 | 03:15 AM
slimmy502's Avatar
ok, i will be getting on this around 2 or 3 today so if you dont mind, please check back. Youve been a great help sir!
Old Mar 28, 2012 | 03:33 AM
slimmy502's Avatar
cel's are 19 and 6
19-automatic transmission lock up control valve (im guessing because im running an auto ecu)
6-water temperature sensor
those are my 2 cels
Old Mar 28, 2012 | 04:44 AM
jbpnoman's Avatar
Ok, make sure your water temp sensor is plugged in. If it is, replace it. They're a relatively cheap part. I wouldn't worry about the 19.
Old Mar 28, 2012 | 05:26 AM
slimmy502's Avatar
did a fuel pressure test and it pretty much stayed between 30 and 40 psi even under a load (i dont have a tach so i assume it was around 2k rpms).
Old Mar 28, 2012 | 05:28 AM
The Grumpiest
Are you planning on checking the timing?
Old Mar 28, 2012 | 05:32 AM
slimmy502's Avatar
Not to seem like a smartass or anything but i snapped this pic like 5 minutes ago
Please pay no mind to the shitty vc lol
Old Mar 28, 2012 | 05:33 AM
The Grumpiest
There are two types of timing; ignition and mechanical. Have you checked them both?
Old Mar 28, 2012 | 05:37 AM
slimmy502's Avatar
I haven't hit the ignition with a timing light but to ear it seems to run and start better somewhat retarded
Old Mar 28, 2012 | 05:41 AM
The Grumpiest
You might want to verify both and NOT play it by ear, so to speak.
Old Mar 28, 2012 | 05:44 AM
kyden's Avatar
what are you trying to show in this pic?
