Quick question - VTEC wiring
Old Mar 27, 2012 | 02:44 PM
KiDDD...'s Avatar
Default Quick question - VTEC wiring
So I've been getting a constant CEL 22 on my y8 swap. I checked the basics, enough oil and all the pins in the ECU are correctly in place...
Now, I decided possibly its a wiring issue. So I'm outside checking out the wiring and something doesnt seem right. There's two wires coming out of the VTEC pressure switch ( a blue one and a black one ) the blue wire runs directly to the ECU and the black wire should be grounded. Well, it is BUT there is another black wire crimped to the VTEC pressure switch ground. As if another source could be getting ground from it? This wire runs into the engine harness and leads to the DRIVER side, not the passenger.
Anyone have any clue what this wire could be and if its possible to be causing the CEL?
before I start cutting the black stuff to find this sucker.
thanks in advance.
Old Mar 27, 2012 | 03:51 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Quick question - VTEC wiring
Take a pic if you can
Old Mar 27, 2012 | 05:11 PM
Arthas's Avatar
Could someone have tried to add a VTEC light? Or maybe a VTEC controller?
I grounded that wire to the chassis and the blue wire went to the ECU. I had no issues and VTEC worked fine.
Old Mar 27, 2012 | 05:47 PM
KiDDD...'s Avatar
I already cut it, basically its a black wire coming from the harness by the driver side, it rides along the inside of the harness itself. That black wire and the ground wire from the VTEC pressure switch were both twisted together and then crimped onto a female connector. Where it then met a male connector directly to ground.
It's possible, I've decided to just follow the black wire tomorrow and see where I end up. I actually ran into a bigger issue. I'll post pics right now, hopefully you guys can help me out.
Old Mar 27, 2012 | 06:11 PM
KiDDD...'s Avatar
Found a even more serious issue. Apparently, my car doesnt have the VTEC pressure switch wired into the ECU.
Here are some specs on the car before we go any further.
93 eg, with a y8 swap. USED TO BE AUTOMATIC. The reason I mention this is because it's possible the previous owner/whoever did the swap probably used the OEM harness the car came with, if I'm not mistaken that's possible right? maybe just have to tweek some **** here and there?
Anyways here are some pics I just took..
The ECU was supposeably a stock 5 speed p28, figured I'd open it up and check it out.
Now, my concern is if he kept the stock auto harness, would the wires and clips that connect into the ECU differ?
Check out pin A4, it has the VTEC solenoid connected but the dude that did it, just cut the orange wire and used that for the solenoid. BUT, if you check out D6, theres a cut wire there but no wire leading out to the engine clips. So all this time I had no vtec!?!?!? lol. frikin amazing.
If anyone can tell me wtf is going on with my harness/ecu/ or whatever, I'd gladly appreciate it.
If someone can tell me what kind of harness this is by looking at the clips/wire colors that would be awesome, better yet, I can check anything for you if you have questions. Thanks guys...check out the pics.
wolfspiritky
Aug 31, 2013 07:59 AM
TXcivic96
Jun 21, 2010 02:12 PM
93(Civic)EG6
Aug 4, 2007 06:10 PM
jdmhatch3
May 7, 2007 06:38 PM
ilovemyb16a
May 18, 2006 12:58 PM
