Cold Wheather
Old Mar 27, 2012 | 12:27 PM
lildragon'07's Avatar
Icon6 Cold Wheather
New b here...
for the past year and a half i have been trying to figure out what is wrong with my car. the scenario is that every time that i park my car for about two days and it rains the next time that I use it, it turns on fine and it will run a few miles, but as soon as i come to stop it turns off and it takes me a while to get it to turn back up again. at this point no one has been able to diagnose it. Does anybody have any suggestions as to why this happens or what could it be causing it??
Old Mar 27, 2012 | 12:30 PM
90civic-ZC's Avatar
Default Re: Cold Wheather
Does it only happen when it rains or any time the car is parked for two days?
Old Mar 27, 2012 | 12:35 PM
for the most part when it get really cold and/or it rains...
Old Mar 27, 2012 | 12:39 PM
singlecamsaint's Avatar
main relay maybe? they can do funny things
TearSDMF89dx's Avatar
sounds like a main relay to me or a bad distributor
Old Mar 27, 2012 | 12:42 PM
i've already changed the main relay twice.... and is it possible that two distributors can be defective from the same company??
Old Mar 27, 2012 | 12:43 PM
whats your fuel pressure?
Old Mar 27, 2012 | 12:49 PM
I'm not sure, i'll check up on it...
Old Mar 27, 2012 | 05:03 PM
91 EF DX's Avatar
you got a cold air intake on it? if so do you have a bypass b/c if not you could get vapor lock on rainy days. just a suggestion
Old Mar 27, 2012 | 05:26 PM
zrickety's Avatar
Have you checked the timing? Where are you getting the distributors? Did you change the plugs and wires too? Filters?
And you made up a word...it's 'weather.' The other word is 'whether' and does not apply here.
Old Mar 29, 2012 | 09:42 AM
Thanks for checking my grammar.... it turns out that the distributor is the one causing the problems, in addition spark number 3 was not properly tightened which was also giving me a backfire at times. As for the distributor i'm looking at different sites to find the best fit for the car and my budget...
Thanks for all the advise.
Blazinmiller
Mar 12, 2024 10:32 PM
DeeJaaY209
12
Sep 26, 2013 12:02 PM
mingbling96
Jun 1, 2006 06:51 PM
DaChoZn1
Jan 9, 2005 05:34 PM
eda6
Jul 30, 2004 10:40 PM
