Header Flanges
Old Mar 27, 2012 | 10:16 AM
end005's Avatar
Default Header Flanges
Curious if its possible or a good idea to cut the flange off a header and welding on a new flange.
For example:
Cutting off D-series header flange and welding on a B-series flange.
Old Mar 27, 2012 | 10:35 AM
that-guy's Avatar
Default Re: Header Flanges
so long as the head port spacing is the same, and your loss of length in the header tubes isnt too extensive to cause clearance issues. just make sure your cut across all 4 tubes is as straight and flat as possible, then clean, bevel, weld. and make sure you use a spare head to fasten the flange to so it doesnt warp
Old Mar 27, 2012 | 08:52 PM
EJAYATE's Avatar
I Deliver
You could grind the weld out with a die grinder and not lose any primary length.
Old Mar 28, 2012 | 09:53 AM
CRMB's Avatar
OG Fabricator
B series center to center port space is 3.54". D series is 3.30". Would likely work ok, just cut off the flange with a vertical band saw and use a metal messaging device (sledge hammer) to fit.
Old Mar 28, 2012 | 10:27 AM
Snow Trooper's Avatar
OG Fabricator
As stated above it isnt ideal but you could make it work. If you have the skills and equipment to do this, you probably are capable of removing the flange and first few inches of the primaries in order to redo it to fit the slightly different layout and not have to bend things.
Old Mar 30, 2012 | 08:34 PM
vtechjunkie's Avatar
Possible? Yes. Worth it? Not in my opinion.
shivic
Feb 18, 2009 07:15 AM
vtec_lude
Welding / Fabrication
Jul 2, 2007 02:23 PM
danielm3
Jan 31, 2006 08:35 AM
lovitalracer
11
Mar 25, 2005 07:10 PM
Rick Solis
12
Jul 29, 2004 12:13 PM
