extended shock towers !!!
i have noticed that there isnt to much that is around here for shock towers being fabbed up to help with lowered efs and da9's...i shaved and tucked my engine bay but my upper control arms banged on the shock towers and punched holes where i welded them in...i would like some ideas for a clean look without looking like someone cut a box or a cylinder open and slapped it on top of the hole and welded it....
thanks much appreciated!
I did these for a local ef owner..........
Mike
Top hats mike extended for me today
IMG_9977 by Tyler_Okuly, on Flickr
IMG_9998 by Tyler_Okuly, on Flickr
IMG_9984 by Tyler_Okuly, on Flickr
Mike
nice ^^i got the koni ground controls with extended top hats...but if i didnt get a good deal i would totally have you make those to go with my shock towers...i wish i owned a tig welder my harbor break special gasless flux core spits everywhere.....
Thanks and no problem I try to help when I can.I will suggest to try to follow the body lines as much as possible so that they dont look out of place.I am going to try to do some minor work on mine to smooth the sharp edges down so they flow a better with the curves on the shock tower.
Correct me if I am wrong, but extending the tophats, won't help with the upper control arm contacting the strut tower will it? But for using a flux core welder on such thin metal, you did a great job man. Looks like just doing it is going to work pretty well for you. I think that the shape of the modification won't matter as much as long as it isn't too boxy. But I will search for my old photos, of a set-up I did on a buddies car not too long ago. I was lucky enough to borrow a tig from a buddy.
Top hats also confuse me.I was under the impression that they would cause the uca to be closer to the shock tower since the shock sits firther up.Even on a setup with adjustable perches they can only be adjusted so much.
Thanks if the comment was meant for me.I also would love to see the pics if you have them
Thats what confuses me it can only help the travel distance on a shock that is compressed due to the drop right I mean a shock can only have as much travel as it was designed for.
Lower the car 2" you just compressed the strut by 2" or went -2 on strut travel. add 2" extention to your top hat you now have a +2 to the equation. Simple math (-2 + 2 = 0) tells you that you're back at 0, which represents the original travel of the strut before the car was lowered (-2). Clear as mud now?
On the Civics pictured, it's more along the lines of 'lower the car 2", you've compressed the shock 1.5"...'.
Extended upper shock mounts also increase shock shaft side loading and increase the likelihood of rubbing the spring on the shock/sleeve
This is common suspension knowledge, and while I'm not always the best at explaining things I'll give it a go.
The upper spring perch is fixed. The shock changes angle during suspension movement, while the upper spring perch doesn't. This loads the spring unevenly, which bows it, which is what causes the rubbing. Move the upper shock mounting further up, and the angle difference between the spring and shock increases, making contact more likely.
Both of my GC sleeves in the front have missing threads from the spring rubbing them.
As for the side loading, the same forces that bow the spring force the shock to bend. Stock, the shock's upper mounting location was already less than ideal. Relocate it further upwards, and you increase the wear on the shock's seals and shaft.
