rebuilding my buddies k20
Old Mar 26, 2012 | 04:29 PM
bonesx0x2x4x's Avatar
Icon2 rebuilding my buddies k20
hey dc5 and ep3 guys....as the title sais im rebuilding my buddies k20a2
i rebuilt a lot of b series engine but never messed much with the k20s...his is out of an 02 rsx
im looking for a litle advice from someone who has messsed with the k20s a little more then me...advice such as stuff to look out for and the things that you should replace on a k20 that u wouldnt on a b series...(such as timing chain tensioner, ect.)..
also will i need any special tools other then typical engine tools?..im aware that the crank pulley can b a b**** to get off without that special tool that holds the crank pulley so where can i get that tool?
thanks for any advice!
Old Mar 26, 2012 | 04:32 PM
Default Re: rebuilding my buddies k20
also any advice on engine removal would b great i know you have to unbolt the subframe which doesnt sound fun
Old Mar 26, 2012 | 04:55 PM
doood's Avatar
been there done that
rebuilding an engine is rebuilding an engine. how many miles on it and what's the reason for the rebuild?
you dont have to mess with the subframe if you're pulling the engine from up top.
Old Mar 26, 2012 | 05:09 PM
Somewhere within the area of 115k...spun a rod bearing but he got a new block with the k24 rotating assembly installed!...
And are u positive about the subframe?...cause all data said u have too
Old Mar 26, 2012 | 05:22 PM
doood's Avatar
only reason to unbolt the subframe is if you're dropping the motor out the bottom. absolutely no reason to mess with it otherwise. just unbolt the mounts, pop the axles out, etc.
Old Mar 26, 2012 | 05:36 PM
Cool that'd b awesome if i really don't thanks
Old Mar 27, 2012 | 05:34 PM
prelude_h22vtec's Avatar
Its true, you can yank it out the top just like the old Hondas.
Old Mar 27, 2012 | 05:56 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I have a full series on youtube on removing the engine and subframe it's easy breezie
search zzfunk13
or look in the stickies I also have them saved in helpful video thread
Old Mar 27, 2012 | 05:57 PM
Thanks guys I'm Gunna pull it out without removing the sub frame
Old Apr 2, 2012 | 08:01 AM
h22steaksauce's Avatar
The subframe removal is easy. Just sounds scary.
Old Apr 13, 2012 | 09:39 PM
spontabr's Avatar
the subframe is easy. although going up and out prolly is best if you dont have a lift. i know on EP3's you have to pop the front bumper off, radiator bracket, radiator, and a few other things but its not bad coming out.
Old Apr 13, 2012 | 11:35 PM
Arthas's Avatar
search zzfunk13
Congrats on your Honda Tuning cover bro.
bigboi407
Apr 18, 2016 04:18 PM
Bulli Kid
Honda Civic (2006 - 2015)
17
Dec 4, 2007 02:24 PM
balbowskie187
Apr 12, 2005 04:11 AM
BoostedJeff
Jan 30, 2005 08:09 PM
