Engine swap in 98 Civic
Old Oct 10, 2002 | 11:23 PM
RSXGeorge's Avatar
Default Engine swap in 98 Civic
I bought a 99 H22A4 motor for my 98 Civic. The motor came with everything except the ECU. I cant seem to find a reasonably priced ECU for this thing. Can anyone tell me which ECU will work with this motor wether it be an integra or civic ECU. I have found that civic ECU's are cheaper than the prelude ECU's. Any help would be greatly appreciated.
thx
Old Oct 11, 2002 | 08:17 AM
Sonic's Avatar
Default Re: Engine swap in 98 Civic (RSXGeorge)
I'm not 100% on this, but you need an OBD2 H22 ECU. Other than that, you can convert to OBD1 and run a P72 (GSR ECU) and have it Hondata chipped to run the H22.
Old Oct 11, 2002 | 09:12 AM
tek_civic's Avatar
Default Re: Engine swap in 98 Civic (Sonic)
not sure about this but couldn't you just buy a cheap aftermarket chip for it? i think skunk2 makes some pretty cheap chips.
Old Oct 11, 2002 | 10:21 AM
exactvox's Avatar
Yes, this setup can be runned, but will cost more than the Lude ECU itself. However, check out some junk yards like http://www.car-parts.com, you can find lots of stuff you need for the H22a swap. Also, get a HCP mount kit for your civic when you do the H22a swap.
Thanks,
Jay
Old Oct 11, 2002 | 10:23 AM
exactvox's Avatar
thx
Do you have the actual H22a4 wire harness? Make sure you do if you do get the H22a ecu.
Thanks,
Jay
japscrap
Feb 17, 2009 03:29 AM
Tip14
Dec 14, 2008 10:14 AM
IA95civicDX
Oct 8, 2007 06:15 PM
98_4drCivic
May 22, 2005 11:30 PM
ELUD THS
Jun 18, 2003 09:13 PM
