2001 w/ H22A Engine Turning but not starting...Help
Old Mar 26, 2012 | 09:24 AM
KiDSoL's Avatar
Icon2 2001 w/ H22A Engine Turning but not starting...Help
So I'm tyring to troubleshoot my friends car he sold me that had a "broken timing belt." So we checked out the timing belt and found out Pep Boys was wrong. (i know blasphemy!) So we checked the fuel pump, fuses, etc. the motor turns fine it just refuses to start. WHat should I begin to check next? I would assume the best thing to check would be the dizzy, but is there a starter relay or anythign else that might be keeping it form starting? I would like to check all the simple things before putting money into igniter coil, dizzy etc...
Edit:
Spark in all 4 plugs so dizzy is fine
Fuel pump working fine.
No compression in 3 out of 4 valves.
The timing belt looks like it has slipped, the other belt that is on the crank for the water pump had no teeth so the debris was everywhere and all int he gears of the timing belt so looks like thats how it slipped.
Old Mar 26, 2012 | 10:46 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: 2001 w/ H22A Engine Turning but not starting...Help
bump for an old schooler... before words in post were green and underlined.
Old Mar 26, 2012 | 01:23 PM
dpetro1's Avatar
How did you check the timing belt? did you remove the timing cover and valve cover? If it broke it could be wedged making it seems to be still intact. If the t-belt is good, then start by checking the mechanical timing and report back
Old Mar 26, 2012 | 04:13 PM
minilogoguy18's Avatar
If there was a problem with the belt then bent valves would keep it from starting if there are enough of them since compression wont be able to build up in the cylinders with bent valves.
If you have fuel and spark then check compression.
Old Mar 26, 2012 | 06:07 PM
jdm_rb20's Avatar
How did you check the fuel pump? I would try a little starting fluid to check for spark (if it fires up for a second). If it doesn't fire up with a little starting fluid, then get a screwdriver and check the plug wires for spark. If it does fire up with starting fluid, then you can rule out the spark being the problem.
Old Mar 27, 2012 | 03:29 AM
KiDSoL's Avatar
Removed the Valve cover and the side cover and there was still even tensions, we then turned the motor from the crank a few revolutions to ensure we saw the whole belt. Then we tried turning the motor again and watched both cams turning and the belt moving..
Sorry if the quoteing didn't work the did they get rid of the multi quote button? We Checked the fuel pump by removing the fuel line from the fuel rail after the fuel filter, gas "squirted" quickly into the cup we put the line in immediately after turning the key.
We bought a spark tester and we were able to get spark at all 4 plugs so we can now rule out it being the coil. The plug tester was blinking indicating a fuel problem but if the pump is working what would be the next thing to check? Would a compression check be the next step, there shouldn't be a reason for bent valves I wouldn't think, it's an auto and he doesn't drive hard at all and it stopped during an idle.
Old Mar 27, 2012 | 06:10 AM
dpetro1's Avatar
how about the mechanical timing?
Old Mar 27, 2012 | 06:36 AM
KiDSoL's Avatar
We have not tried that yet. Can that be checked without the car starting and if so can you explain how?
Old Mar 27, 2012 | 03:40 PM
jdm_rb20's Avatar
Hmmm...got spark, got fuel... Time to start guessing: double check ALL grounds especially battery>>body, engine>>> body grounds. Use a voltmeter to verify that you have voltage on the outputs of the ignition switch (when the key is in each position). Have you checked for CEL's?
Old Mar 27, 2012 | 03:56 PM
Honda Sport's Avatar
CEL? I know the CKP gets picky and sensitive at the crank pulley. had to replace it twice after doing a t-belt and water pump. same symptoms as yours. crank but no start. the 2nd time I had to replace it, the lower belt cover was cracked so it had a little bit of dirt and water inside. just enough to get a CEL. replaced the CKP under warranty. replaced the cover and the sensor. been good for the last 6-7 months now.
Old Mar 27, 2012 | 04:22 PM
KiDSoL's Avatar
Is there a way to test it? Theres no CEL atm but the motor hasnt be able to run and we get no CEL with the key in Aux position. That might be relevant though, what did that sensor cost you and where did you get it?
Old Mar 28, 2012 | 05:30 AM
dpetro1's Avatar
the engine would not be running to set mechanical timing. basically you set the crank to TDC, then check to make sure the cams are also lined up at TDC
Old Mar 28, 2012 | 05:35 AM
gozy's Avatar
I have the same problem, im going to take my car to a tech this weekend ill keep u posted. If i find my problem, maybe it will help your problem.
Old Apr 3, 2012 | 07:39 AM
KiDSoL's Avatar
Update:
No compression in 3 of the 4 pistons, currently working on checking the mechanical timing, looks like 1 cam might be a tooth off but we aren't completely sure. Have to get a tool to take off the crank pulley and then we will know.
Anythign else we should check ?
Old Apr 3, 2012 | 10:11 AM
dpetro1's Avatar
you do not need to remove the crank pull to check or set the mechanical timing. if the timing is off, you can loosen the tensioner and reposition the belt, then reinstall.
if you aren't getting compression on certain cylinders, the valves may be bent
Old Apr 5, 2012 | 05:53 AM
KiDSoL's Avatar
Here is where the arrows are on the cams
This is where the crank is whent he cames are in the position on the top picture.
Should line on the crank be at the top and match the cams (arrow markings.)
There wa sno markings on the crank pulley like the diagram you posted mentioned.
Old Apr 5, 2012 | 09:18 AM
dpetro1's Avatar
do it the opposite way. put the crank to tdc, then see where the cams are.
Old Apr 5, 2012 | 11:33 AM
afrotec's Avatar
For me, it was helpful to use the lines marked on the cam gears instead of the stupid arrows. The lines are on either side, 90degrees from the arrows. They should meet in the middle and line up with the edge of the valve cover.
Old Apr 5, 2012 | 03:11 PM
vinuneuro's Avatar
This isn't B series. Take off the pulley and look at the marks on the timing gear and oil pump. Get yourself the appropriate helms.
Old Apr 5, 2012 | 04:30 PM
dpetro1's Avatar
is there not a reference point on the crank pulley? what about ignition timing?
thekeysarebroke
15
Oct 1, 2012 05:35 AM
kldjjt
Mar 21, 2012 10:19 AM
zmods
Mar 20, 2011 03:06 PM
jerryscherry
18
Mar 24, 2010 10:37 AM
