Putting the motor back together tomorrow...cant have my cometic leak....Install tips?
Old Oct 10, 2002 | 10:47 PM
IntegD's Avatar
New User
Default Putting the motor back together tomorrow...cant have my cometic leak....Install tips?
Other than using two coats of copper spray on both sides, is there any other tips you all know of that will hopefully ensure the sealing? Ive read past threads where people have problems with their cars smoking because so much coolant in the combustion chamber.
It wont make a difference that I have 81.5mm bore and the gasket is 81mm right? I ordered it because my block was decked before and I needed to lower my compression a little with the JE 9.8:1. Stock gasket sealed just fine last rebuild....any tips?? Really dont want to have to pull it all back out after I finish.
Old Oct 10, 2002 | 10:52 PM
LsTurbo91's Avatar
Default Re: Putting the motor back together tomorrow...cant have my cometic leak....Install tips? (IntegD)
where did you get the copper spray?
Old Oct 10, 2002 | 11:02 PM
IntegD's Avatar
New User
Default Re: Putting the motor back together tomorrow...cant have my cometic leak....Install tips? (LsTurbo91
Dont have it yet..going to try to pick it up at a local auto parts store like napa, pep boys, or autozone. Any tips?
Old Oct 11, 2002 | 03:38 AM
Farnsrocket's Avatar
Napa has it.
b16 matt
Jan 30, 2008 11:53 AM
W O T
Mar 23, 2006 12:57 AM
d16dcoe45
Oct 5, 2005 05:26 PM
Type_gsR
Feb 3, 2004 04:43 PM
schwett
Jun 18, 2002 06:22 AM
