help please! overheating ..
like the title says , my little hatch keeps overheatingg .
it has brand new water pump, thermostat and cap all installed yesterday .
but the stupid thing keeps overheating .. the timing is all good as well
im at my wits end .
its a b18a1.
thanks ! much is appreciated for any help at all .
im at my wits end .
its a b18a1.
headgasket doesnt seem to be leaking , no water in the oil .
im going to swap out the rad hoping tht fixes it .
there isnt any obvious leaks that i can see, then again it could be pushing out a pin hole crack or from one of the tanks is seperating ..
well i did a pressure test of the cooling system, everything checked out good , so with a small last ditch attempt, i deleted my heater core . holds strong now . also added another fan .
on the coupler for the top rad hose on the motor there is a bleeder valve, thats how you get rid of the air pockets in your coolant, it doesnt take much of a air pocket to make your car overheat, its a 10mm bolt with a little nipple on top of it, jus start your car and let it idle then open it a little, it will spit out coolant but if theres air pockets it will spit that out to, jus like brakes wait til its a constant stream of coolant then tighten it n your good on that, jus dont tighten it to tight, it can break easily, a compression test would be a good thing to try also
