Trying to figure out what kind of transmission i have.
Looking to get pointed in the right direction and find out what kind of transmission i have in my H swapped eg. Here are few pics any help would be much appreciated.
If you want to check, pull the axles out and look through the axle hole to see if there is a spider gear pin. A LSD will not have the pin inside. The install mechanic should have no problem showing this to you but he will charge to pull the axles if the job is already finished.
LSegHatchy
Oct 28, 2004 12:20 PM
tallblondkid
32
Jul 11, 2004 08:36 AM
dwchkypmp20
Jan 4, 2004 01:36 AM
