just got back from the track:( (kinda long)
Well I just had a depressing night of running the car. Let me start off by posting my BEST run.
r/t- .662
60'- 2.444
330- 6.801
1/8- 10.449
mph- 66.48
1000- 13.608
1/4- 16.279
mph- 83.95
So that was my BEST run remember... Out of the 8 runs that I made my times ranged from that to a 16.44 @ 85.88 mph with a 2.483 60' foot time. I have a 91 crx si w/ d16y8, p28 ecu (using a jumper harness), OBD-1 dist, I/H/C/E, running the obd-0 injectors through the injector resistor box at 42psi. What the hell is going on
. I orginally had the fuel pressure set at 47psi a few weeks ago and the car felt better, power tonight was dying off at 6900 rpm. I think it is because I am not getting eanough fuel pressure when VTEC hits, but who knows...............
r/t- .662
60'- 2.444
330- 6.801
1/8- 10.449
mph- 66.48
1000- 13.608
1/4- 16.279
mph- 83.95
It was about 75-80 degrees and dry. Yeah I know that my 60' times suck... I tried everything from feathering the clutch, to, diffrent rpm ranges, but everytime I got about the same consistent 60' times. I am going to work on it though. Thanks for the reply
reminds my 4psd tranny on the Z6 when i first tried it.. gave me a 16.9.. sucks.. anyways i am going back as soon i fix the damn electric load i got..
I am running a 91 crx si tranny, that I had rebuilt like 10k miles ago.... For alot of my slips I was beating the contender next to me through the 1/8th mile, then as soon as 3rd gear hit I would get walked..... How much total et do I gain by knocking off a tenth of my 60' time??? Thanks
Hmmm. Your Y8 should definately be faster than that. On my Y8 in my CRX I had the OBD-I conversion (homemade) running the Y8 distributor, P28 ECU, Y8 injectors, and I had fuel pressure set at around 37-38 psi, with timing advanced 2 degrees; I was pulling 15.3's all day with only an I/E, stripped interior + no passenger seat... Best run was a 15.2, best MPH was 90.
Anyways, check your cranking compression. Sounds like maybe you have a dud motor. And I'm pretty sure you shouldn't be running OBD-O injectors and a resistor box...
[Modified by 89_Y_49RIP, 9:01 AM 10/12/2002]
for every 0.1 in 60' times, take 0.2 off your total et.
el arbi
Apr 29, 2003 07:19 AM
turbodsmpower
Apr 12, 2003 02:26 AM
