Rubber gasket for Front Lip Spoiler
Recently I cracked my front lip (rebar sticking out of a bumper block grabbed it). So I had it repaired, but the rubber gasket was trash. So I tried out the toyota one (07-xx Camry for the rear lip).
I was looking for OEM ideas and found a guy on clubrsx that had used some other shorter pieces to do the sides of his front lip and someone on that thread suggested using the camry rear lip one to do the entire lip instead of just the side pieces.
http://forums.clubrsx.com/showthread.php?t=814140
Not that its super noticeable on a black car, but on his silver it really helps fill the gaps (last picture on his thread is the "before shot). It also helps from wearing the paint off your front bumper where it mounts up.
Overall I was very happy for the $15 I spent on it.
i did the same exact thing when i painted my car a few weeks ago for the oem lip and side strakes. Toyota gaskets work perfect and look like honda oem. The reason im guessing he didnt use the Honda ones is because they make you buy the whole front lip just for the gasket, thats what they told me when I tried to order one as well
The one on mine apparently broke when they took it off and they only put part of it back on. Damn lip has scratched my bumper all up where grit has got between it and the bumper.
Or just buy the Honda OEM part?
08F03-SHJ-1100D (black front lip molding)
*edit*
I like HardTopGuy but it bothers me he won't list the OEM part numbers for things. You can save yourself $$ by going straight to Honda for this stuff.
*edit*
I wouldnt have actually thought of this since i'd seen the strip on HTG's site. Although, I work for Toyota so this seems like a pretty simple solution for me. Best part is, my cost is only $12, thanks for the idea!
