Buzzing noise at highway speeds ?
Old Mar 24, 2012 | 01:45 PM
Rob.'s Avatar
Icon2 Buzzing noise at highway speeds ?
1990 CRX Si.
Im getting a buzzing noise mostly on the highway.
It starts at around 45-50ish and sounds very faint. As I go faster it get's increasingly louder.
It sounds like it's coming from behind under the dash in the steering column area.
I read it could be the speedometer cable needs grease ?
Any ideas ?
Old Mar 24, 2012 | 02:44 PM
EFnCRX's Avatar
Default Re: Buzzing noise at highway speeds ?
Is your speedo needle bouncing? There is actually oil that flows through the speedo cable try unplugging it and take it for a spin you wont know your speed but if there is no noise you'll know what's causing it hope this helps!
Old Mar 24, 2012 | 02:47 PM
Rob.'s Avatar
No.
I would have stated that in the initial post if it was.
Where do I unplug the speedo cable from ?
Old Mar 24, 2012 | 02:54 PM
EFnCRX's Avatar
back side of the cluster top left corner.
Old Mar 25, 2012 | 11:24 AM
Rob.'s Avatar
A quick google search brought me to this:
http://www.gnttype.org/techarea/body...eedocable.html
Seems like the speedo cable needs lubing or the bearings inside the speedo head are toast !
Old Mar 25, 2012 | 06:52 PM
jdmboyef9's Avatar
I had this same problem on my old car. Started off light and then got worse causing the needle to bounce and it sounded like the brake pads
BigDrJ14
Mar 10, 2011 07:19 PM
manyakiexpi
Mar 13, 2006 06:24 AM
B16CRXT
Feb 20, 2004 12:34 AM
02WRX
Mar 7, 2002 05:47 AM
