MFactory shaft brace "CUFF"
Old Mar 24, 2012 | 10:30 AM
andersen's Avatar
Default MFactory shaft brace "CUFF"
So I just got my MFactory shaft brace "CUFF" and was looking to see if there was any install right ups on here and couldn't find any. I know the basics of how to install it just wanted to see if there was any helpful tips out there. Like how do I know how many of the spacers that come with it I should use or should I use assembly lube ect.
Old Mar 24, 2012 | 10:40 AM
sanman000719's Avatar
Default Re: MFactory shaft brace "CUFF"
this is a liberty install but should be close to the same
https://honda-tech.com/forums/drag-racing-36/tranny-rebuild-darnell-p-liberty-cuff-h-t-pix%2A-2847380/
Old Mar 24, 2012 | 11:01 AM
andersen's Avatar
Yes I seen this it has some good pics but that's about it. More or less just want to know if there are any measurements I need to take before I pull the 5th gear off.
Old Mar 24, 2012 | 11:06 AM
all i did was pull 5th lay 3 spacers down, and put the stake nut back on. 3 was to many because reverse didnt wanna stay in gear (kept popping out). pulled 1 spacer off and walla.
pretty much do it till it works for you
Old Mar 24, 2012 | 07:22 PM
andersen's Avatar
Nice that helps. Would be mad that I had to drop the tranny because it wouldn't stay in reverse. Anyone else have any inputs?
Old Mar 28, 2012 | 09:43 AM
andersen's Avatar
Ok so I got mine in yesterday. It is way simpler then I thought it was going to be.
(THE LAST PIC IS EVERYTHING YOU TAKE OUT)
94lsvturbo
Aug 4, 2010 05:45 PM
1QwIkEf
Transmission & Drivetrain
Sep 17, 2009 07:49 PM
be18see1
Feb 17, 2009 08:14 PM
vacantskies88
Sep 4, 2008 02:04 PM
Dee
Jan 21, 2002 03:11 AM
