Knock sensors? Quick and easy question.
Old Mar 24, 2012 | 05:15 AM
BowtieHonda's Avatar
Default Knock sensors? Quick and easy question.
OK. So the old, worn out, leaking from every hole H22A is out of my '97 Prelude. The F22B DOHC is buttoned up and going in today. I have everything sorted out and good to go.
When I was swapping sensors over, I noticed the knock sensor on the H22 was broken. The knock sensor on the F22B is in great shape. Both use different hole sizes. Can I just hook up the F22B knock sensor? They are both one wire hook up, I have a hard time imagining that one would send a different signal than the other. They just use different connectors so I would have to take the connector off of the F22 harness and stick on my H22 harness right quick. I already swapped the oil sensor over from the H22A and took the lower plug out at the back of the block and installed it on the F22B.
That's all!
Thanks.
Old Mar 24, 2012 | 08:03 AM
97ludedude's Avatar
Default Re: Knock sensors? Quick and easy question.
It should be fine. Give it a try the worst that will happen is that it will throw a code for the knock sensor. I doubt it will be too senstive, which would cause the ecu to pull timing all the time.
Old Mar 24, 2012 | 03:29 PM
minilogoguy18's Avatar
Yeah, someone I work with needed one bad and used a sensor from a 06 civic LX in a D series, just put a different connector on the harness.
Old Mar 24, 2012 | 10:05 PM
That's what I was figuring. Thanks guys. I swapped the connectors and put the engine and transmission back in the car today. Hopefully running by next weekend
Old Nov 28, 2012 | 11:31 PM
96preludebn's Avatar
I'm doing a h23 swap to a f22 tomorrow if you have any advise to make it go a little smoother plz comment, I'm trying to get all the help I can. Thanks
Old Nov 28, 2012 | 11:41 PM
holmesnmanny's Avatar
answers.google.com/answers/threadview?id=272435
der3k
Apr 19, 2014 11:21 AM
ach2291
Feb 11, 2013 08:23 PM
JDMislander
Mar 26, 2010 06:01 AM
97blacklude
Jan 31, 2009 09:56 AM
StickyDilJoe
May 20, 2003 09:30 AM
