Acura el climate control swap
Old Mar 23, 2012 | 06:15 PM
santii7's Avatar
Default Acura el climate control swap
Can anyone tell me the Pinout for the plug for the hazards and the clock?
Hope somebody knows! I did research and found nothing
Old Mar 23, 2012 | 06:17 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Acura el climate control swap
Why? I've never read that you needed to repin anything with this swap.
Old Mar 23, 2012 | 06:26 PM
santii7's Avatar
Only the hazards. It plugs in but it's a different Pinout. And im planning to wire in the clock to the radio harness
Old Mar 23, 2012 | 07:47 PM
santii7's Avatar
Bump
Old Mar 24, 2012 | 03:45 AM
santii7's Avatar
Bump
Old Mar 24, 2012 | 01:47 PM
santii7's Avatar
Anyone?
Old Jun 10, 2012 | 06:22 AM
santii7's Avatar
Ttt
Old Jun 10, 2012 | 06:57 AM
92lxsleeper's Avatar
don't you know how to use a wiring diagram, and a multimeter, or test light?
Old Jun 10, 2012 | 07:05 AM
santii7's Avatar
I do.. Figured I would save myself the trouble and see if anyone has done it. ......
Old Jun 10, 2012 | 07:06 AM
i haven't done it, but i know its not hard if you ahve a multi meter
Old Jun 10, 2012 | 07:15 AM
The Grumpiest
Since March?
Old Jun 10, 2012 | 07:45 AM
santii7's Avatar
Dam ur all up in my ****.. Yes since march I haven't got the chance to work on my car it's been sittin in my garage I've been busy with work
Old Jun 10, 2012 | 07:56 AM
The Grumpiest
I guess I am because in a couple of minutes I found this.
Originally Posted by Crx150zc
Next oh good the hazard switch is the exact same plug but upon trial you will find out turning on your new hazard switch freaks out the car and powers up the ignition, you could skip the trial and just know that you have to cut and spice the new connector in or re-pin the plug, the wire colors are an exact match just in different locations in the plug.
And I'm studying for finals right now.
What part of this is tripping you up? YOu probably have to do the same with the clock. If not, use a multimeter. Or you can wait another three months to tell the time.
Old Jun 10, 2012 | 08:08 AM
santii7's Avatar
This. I already read that thread before
Im just going to figure this out on my own when I get the chance and probably do a diy thread since there's none for this
I already did the clock
Old Jun 10, 2012 | 08:09 AM
The Grumpiest
I guess this is the part tripping you up. Repin and match up the colors.
Old Jun 10, 2012 | 08:13 AM
santii7's Avatar
I dont have the pig tails for the el plug so I can't match anything up
Old Jun 10, 2012 | 08:18 AM
The Grumpiest
Wow! And you don't think it would have been prudent to mention this 3 months ago? Regardless, the wires are the SAME COLORS!!! Match them up! If you don't trust that guys explanation then you need to take the time and use the proper tools; AKA a multimeter. You said nothing of this in your first post and said you found NOTHING. You could have checked it by now.
Old Jun 10, 2012 | 09:21 AM
why don't you google. acura EL hazard switch pinout
Old Jun 10, 2012 | 09:24 AM
The Grumpiest
He's too busy.
Old Jun 10, 2012 | 09:26 AM
Originally Posted by grumblemarc
He's too busy.
omg. it takes two seconds.
here ---> http://lmgtfy.com/?q=acura+1.6EL+hazard+switch+pinout
BLAZE_EK
Jun 5, 2011 04:18 PM
shotenITR
Apr 25, 2008 10:38 AM
CO_HaTcH
12
Aug 24, 2007 07:36 PM
HxC_TegGirl
Apr 1, 2007 12:05 PM
charjacq
Jun 11, 2006 02:03 PM
