oBD0 code 11
Old Mar 23, 2012 | 11:57 AM
ohgodbadname's Avatar
Default oBD0 code 11
My ecu is throwing code 11, and from all my research, no one seems to have a description for it... Does anyone know what code 11 is. One guy suggested it was an ABS sensor, but hes the guy i bought it off, so for all i know, he could be giving me a line of BS lol. I trust the guy, but if someone could verify, that would be awesome.
Thanks!
Old Mar 23, 2012 | 12:16 PM
crx<3's Avatar
Default Re: oBD0 code 11
there is no code 11. maybe your not reading your ecu correctly.
Old Mar 23, 2012 | 01:55 PM
sanimalp's Avatar
$cat /dev/urandom
There is a code 11.. it is for cars that were sold without a catalytic converter.. Code 11 is for a sensor called the IMA sensor.
The IMA sensor manages how much CO is in the exhaust using the O2 sensor as a guage.
Since you didn't mention what ECU you are running, its a guess, but my money is on that you have an ECU looking for an IMA sensor, and a car that doesn't have one.
Your options are to get a different ECU that does not expect an IMA sensor, or do the work to install the IMA sensor the ECU is looking for.
Old Mar 23, 2012 | 02:44 PM
crx<3's Avatar
my bad i was going off usdm.
Old Mar 23, 2012 | 07:05 PM
Im using a mp7. Sorry about that, thought i mentioned.
Pm7s on a 91 ef with a dohc zc. Does this sound right?? My car has a cat converter btw, but i guess jdm efs with a zc didnt have one?
Old Mar 23, 2012 | 08:26 PM
sanimalp's Avatar
$cat /dev/urandom
Your problem is exactly the one I describe then.. The PM7 is one of the ECU's that has this problem. Your choices are to wire up the IMA sensor, which i would say is a waste of time and energy, find a new PM7 that is not one that looks for the IMA, or find a chipped PM6 and run PM7 maps in it.
Out of those 3 options, the chipped PM6 might be the easiest.. talk to chris or any of the people at xenocron.com and he can get you the ECU you need.
Old Mar 24, 2012 | 01:30 PM
Im only going to do one of these things if it will have a BIG impact on my etest. im failing by 1000ppm (limit 200ppm, im running 1200ppm at idle!)
You posted on my other thread. Im thinking i have a jammed wide injector... Thoughts??
Old Mar 24, 2012 | 02:06 PM
crx<3's Avatar
my thoughts are to go with one of sanimalp options, it should have a big impact on your test or at least get you somewhere in the ballpark.
if you think its your injectors take them out inspect, and test with a multimeter.
Old Mar 24, 2012 | 08:50 PM
sanimalp's Avatar
$cat /dev/urandom
Doing one of the things I mentioned will absolutely have a huge impact on your e-test. Right now, that ECU is looking for a sensor that is used to control your car's emissions, and not finding it at all.
I bet even getting a PM6 that isn't chipped would be a substantial improvement to what you have now.
Old Mar 26, 2012 | 06:14 PM
Well I had a chipped PM6 in it before, as well as a virgin PM6, but even still, it was failing in and around 1200ppm. If anything, the PM7 brought it down. I found a thread where someone (ZCRacing is his username) give some instructions to run the O2 sensor as the IMA sensor, or something along those lines. Honestly, running an IMA sensor might not be such a bad idea. His post suggested splicing some wires here and there.
But my main concern in doing a bunch of work the wont solve the problem. Im not being lazy lol, I just an a busy dude! These are some figures im getting...
Curb Idle
HC ppm - limit = 200 reading = 1278
CO % - limit = 1 reading = 6.89
NO ppm - limit = 864 reading = 2470
So going with those numbers, what do you think, will the ecu fittling do it justice and pull those numbers down? or do i have something hideously whole with my engine? lol
Old Mar 26, 2012 | 06:16 PM
*hideously wrong
Old Mar 27, 2012 | 08:05 AM
jlicrx's Avatar
European (mainly UK) PM7 ECUs had the IMA sensor, not JDM - the ECU pinouts for the PM7 with IMA are not the same as other PM7 ECUs - find a JDM PM7 or use 88-89 PG7 or PM6
this is UK PM7 with the IMA sensor:
Old Mar 27, 2012 | 12:16 PM
Hey jilicrx, thats super helpful, thanks! Ive spent so friggin long looking for PM7's, and the one I find doesnt work :/ Its just frustrating that i cant get a damn ecu that works! I ran a PM6 before and the emissions were about the same. There has got to be something wrong with the engine, asides from the ecu. If a PM6 didnt fix it, or at least bring it down, I doubt its ecu related. Is that too bold a claim??
Old May 8, 2024 | 06:28 PM
Azthioth's Avatar
I know this is a super old thread, but I have a P29 ECU on a ZC motor without a o2 sensor or cat. Does the IMA sensor work in their place in a situation like this?
B16afmaxt
Dec 3, 2012 07:17 PM
dbailey
21
Nov 9, 2007 07:08 AM
SpoolnByYou
15
Mar 26, 2006 08:43 AM
MAD-racer
May 10, 2005 04:44 AM
Mattb16teg
Jan 25, 2005 05:51 AM
