What's the difference between a 2nd gen and 3rd gen half shaft?
Old Mar 23, 2012 | 03:58 AM
kanted's Avatar
Default What's the difference between a 2nd gen and 3rd gen half shaft?
I have a half shaft off what is believed to be a 96 and it fit my 93 other than it was female on the end that went to the cv axle. it bolted up to the block fine and seem to fit in the tranny fine. i took it down the road and i'm leaking oil bad. did i mess up my seal or are the newer ones shorter so it wont seal?
Old Mar 23, 2012 | 02:08 PM
Turboteg27's Avatar
Default Re: What's the difference between a 2nd gen and 3rd gen half shaft?
its prolly the seal. their all the same length goin into the tranny. sometimes when you pull the halfshaft out of the tranny the seal will come out and stay on the halfshaft. so make sure u have a seal in your tranny, and make sure u dont have a seal in the tranny and a seal on the halfshaft at the same time.
Old Mar 23, 2012 | 02:15 PM
Deetz's Avatar
Crazy Honda Guy
Old Mar 24, 2012 | 03:16 PM
kanted's Avatar
I had it backwards, the newer shafts are male goin into the axle. Either way I've got the right one on order and I'll grab a new seal so there'll be no guess work. Much appreciated.
sirEGhatch
Transmission & Drivetrain
Mar 24, 2010 01:27 AM
VTECrUS
Jan 6, 2009 05:32 PM
Ricey McRicerton
14
Nov 19, 2008 05:17 PM
BoostinEJ1
Jun 6, 2007 02:15 PM
