D16Y8 -- oil leak from bad head gasket
Old Mar 22, 2012 | 11:59 PM
Robotin's Avatar
Default D16Y8 -- oil leak from bad head gasket
my '97 EJ6, started to leak oily badly between the head and the block. i was losing half a court of oil every 2 days..... it happened all of a sudden.
i pulled the head to replace the head gasket and the gasket was undeformed, no cracks, no rips anywhere. so when i pulled the head there was alot of coolant on the pistons....
im stressed because im worried that swapping the HG wont fix it. and i dont wanna have to strip down the motor again....
any help... please... what i could do..
or am i just tripping?
Old Mar 23, 2012 | 12:01 AM
jbpnoman's Avatar
Default Re: D16Y8 help...
Pictures would be useful, or at least where between the head and the block it was leaking from.
Of course there was coolant in the cylinders - you took off the head without draining the system first.
Old Mar 23, 2012 | 05:02 AM
Former User's Avatar
Use a precision straight edge to ensure that the head and block mating surfaces are perfectly flat before installing a new head gasket.
Old Mar 23, 2012 | 05:03 AM
grumblemarc's Avatar
The Grumpiest
Where EXACTLY is the leak coming from? Exactly.
Old Mar 24, 2012 | 10:30 AM
motegicivic's Avatar
Default Re: D16Y8 -- oil leak from bad head gasket
Are you sure it was leaking from the headgasket, super rare for honda's leak oil from there.
Old Mar 24, 2012 | 04:03 PM
zach53's Avatar
double check the block deck and the head make sure they are sealing.....u may need to get the head shaved....idk hows your oil look?? is the leak like right under the dizzy kinda by the stat housing???
Davis2
Feb 12, 2017 06:12 PM
ArtyTheKid
Feb 25, 2013 08:29 AM
scspeed
Apr 18, 2009 01:54 PM
R6Elmo
Nov 13, 2003 04:47 PM
