fog lights killed my car
ok so here we go
i installed some foggies in my eg coupe wired everthing correctly the fogs work great but now my car wont turn over at all it doesnt even try... clutch to the floor turn the key and one click then nothing....
I check all the fuses under the dash and hood by the batt all are fine
my grounds are fine down to bare metal.
Im at a loss
any help
Im at a loss
any help
FIRST check to see if that clutch switch "stopper" hasn't fallen off.
If that isn't the problem then remove that fog light kit. Return wiring to stock.
Dont wana sound dumb but check your terminal connections, i assume u disconnected the battery before u installed? Also make sure u disconnect both and reconnect both respectively before u try again.
problem fixed
disconnected fogs
back to oem wiring
then hooked fogs again in a different order on the terminal
cars alive and fogs are functional
many thx
grumple and tahiitian
disconnected fogs
back to oem wiring
many thx
BIGthings
Feb 10, 2007 07:35 PM
