90 integra ls wheel squeak over 25 mph
sup guys.
my integra is making a squeek noise from the driver side wheel when i go over 25mpg. sumtimes it also makes my speedo bounce.
i replaced the struts and forks. and axles. lowerball joint. :/
I'm willing to bet it's your speedo cable, especially if your speedo's bouncing. I've gone so far as to replace a wheel bearing, trying to lose that noise, before I found out what it is. The noise is actually coming from the grease-starved cable, with the squeak transmitting up the cable to the speedometer in your dash cluster, making you think it's coming from the driver's front wheel. Check it out.
BigDrJ14
Mar 10, 2011 07:19 PM
B16CRXT
Feb 20, 2004 12:34 AM
