integra gsr dowel pin?
Old Mar 22, 2012 | 01:25 PM
MurtazaDSM's Avatar
Default integra gsr dowel pin?
I was going through the box of parts from my head that the machine shop gave me. I was putting the upper water neck and vtec solenoid back on the head and came across this in the box
I was wondering what it is. It looks like a dowel pin for the vtec solenoid but where does it go? Here is a pic of it compared to a dowel pin for the block
Old Mar 22, 2012 | 05:38 PM
guess_who's Avatar
Default Re: integra gsr dowel pin?
It may be the one for the water pump?
Old Mar 22, 2012 | 05:50 PM
1998GsRIntegra's Avatar
Check to see if the dowel pin and o-ring are under cam cap #3. If they are not present, that's where your dowel pin goes. Vtec will not work with out it.
Old Mar 23, 2012 | 10:35 AM
MurtazaDSM's Avatar
yup its the one under cam 3 now I need to order the oring.....also when installing arp head studs should I put thread sealer on the threads that go to the block or should I just use oil to lube them or put them in dry
Ben Petrocelli
May 4, 2019 04:46 AM
xlonelydrifterx
Feb 12, 2019 10:11 PM
PushnFords
Honda Civic (2001 - 2005)
Jan 10, 2018 09:58 PM
Sethgreen
Nov 26, 2011 11:51 AM
poorman's type-r
Jul 28, 2006 04:10 PM
