D16Z6 High idle 1k - 1.5k (increases with temp)
I have a D16Z6 in a 93 del sol with a p28 ecu, when i start it up cold its around 1000rpm and it goes to about 1500rpm when its fully wormed up. It also dies down once i go past 6000rpm and it normally limits around 7200. doesnt fluctuate or any thing.
Ive replaced the IACV, cleaned and adjusted FITV, adjusted the cable, cleaned the throttle plate, the idle screw is all the way in and i had to adjust the stopper cause it was sticking in the bore, replaced the distributor for previous repairs
thanks
thanks
sweetbbyrays
Apr 11, 2012 07:28 PM
Jonathan_ED3
Jan 13, 2009 03:15 PM
